Shifter Handle
  • Thread starter Thread starter foxmustangman
  • Start date Start date Dec 28, 2007
foxmustangman
196
Idaho
Dec 28, 2007
  • Dec 28, 2007
Okay, So I'm trying to put in my B&M shifter and I can't seem to get my handle off of my stock shifter. I was told you could just smack it with a hammer? Does it pop off, does it screw off? What? Thanks.
fastford91
254
Niagara ,Ontario, Canada
Dec 28, 2007
  • Dec 28, 2007
are you talking about your shifter knob? or the whole shifter? if it the knob there is a set screw you need to undo and it should come off! if it the whole shifter here is a how for you! On late models you'll need to remove the shift knob, console cover, and upperboot. There is also a lowerboot attached with four hex-head screws, which can be tricky to get to. You don't need to drain the trans fluid to change the shifter. Start by removing the four 13mm bolts which secure the stock shifter to the transmission.
With the bolts out, use a screwdriver to pry the stock shifter off the case.
You can see the difference in construction between the Ripper and the stock shifters. The stock shifter base is stamped steel and will flex under heavy force. The Ripper uses an all billet aluminum design. The stick itself is stainless steel. View attachment 339849
Inspect the small plastic shifter cup. If it is in good shape (they usually are), it can be reused. Otherwise you'll need to round up a replacement, from Ford or a transmission shop. View attachment 339851
Scrape off the old silicone, and apply a bead of new silicone sealant or RTV.
Carefully place the new shifter onto the case, making sure that the shifter ball seats into the plastic cup. The new shifter comes with offset washers which allow you to position the shifter 1/2" fore or aft, based on your preference. Install and tighten the supplied allen head bolts. View attachment 339853
The shifter stops are an important feature of T5 aftermarket shifters. They will prevent overtravel of the shifter when your slamming the gears. One big problem with the stock shifter is that if bang the gear hard enough you can damage the internals and bend the shift forks. Set the stops by putting the shifter in third and turning the allen screw until it just touches the stick, then back it of half turn. Repeat for the lower stop with the shifter in fourth gear.
While holding the allen screw in place, snug up the lock nut. Go ahead and shift through all the gears and make sure all the bolts are nice and tight. View attachment 339855
The final step is to slip on the supplied boot and retaining ring. You're now ready to slam the gears with confidence! The B&M Ripper definitely changes the feel and action of shifting. The throws are shorter and thus faster. The shifter also offers more positive "cluncks" when engaging gears, without the sloppy feel and play in the stock shifter. hope this helps you !James
foxmustangman
196
Idaho
Dec 28, 2007
  • Dec 28, 2007
Oh it's just the knob. Thanks though!
StangerT
9
Meridian, ID
Dec 31, 2007
  • Dec 31, 2007
foxmustangman.. you do the AOD swap???
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Dec 31, 2007
  • Dec 31, 2007
no its an auto shifter..
b&m hammer shifter if i remember right.
foxmustangman
196
Idaho
Dec 31, 2007
  • Dec 31, 2007
Nah, I wish. I'll do it a few years down the road. For now my ratchet hammer is fun! What do you have StangerT?
ryan218
Dec 28, 2005
columbus ohio
Dec 31, 2007
  • Dec 31, 2007
ya me too, my auto whines i hope it blows.
foxmustangman
196
Idaho
Dec 31, 2007
  • Dec 31, 2007
LOL so does mine. When it's cold it just whines and whines! I tell people its my supercharger!
So now I just tear the crap out of it since I'm swapping it this week.
ryan218
Dec 28, 2005
columbus ohio
Dec 31, 2007
  • Dec 31, 2007
mine down whine that bad, i wish it would just throw something...
so far 3 4,500 Netrual to drive bombs and its still going
foxmustangman
196
Idaho
Dec 31, 2007
#10
  • Dec 31, 2007
  • #10
LOL. Hey I got a question, since we're talking about transmissions...
Do you hold 2nd gear ever, or do 1d1, etc?
StangerT
9
Meridian, ID
Jan 1, 2008
#11
  • Jan 1, 2008
  • #11
I am graced with the anchor as well - (with the added bonus feature of having no O/D due to an aod TV cable mishap) - All you need to do to pop that knob off is push in the knob and give it a good tug... If/when you ever do the aod swap, give me a hollar... I would like to see how its done... I'll even provide some free labor
ryan218
Dec 28, 2005
columbus ohio
Jan 1, 2008
#12
  • Jan 1, 2008
  • #12
ya ive only held it in a second like 3 times so far....u did the 1 d 1...
foxmustangman
196
Idaho
Jan 2, 2008
#13
  • Jan 2, 2008
  • #13
StangerT said:
I am graced with the anchor as well - (with the added bonus feature of having no O/D due to an aod TV cable mishap) If/when you ever do the aod swap, give me a hollar... I would like to see how its done... I'll even provide some free labor
Yeah, That's why I need a new one too. Some help would be appreciated, thanks.
I asked 'cuz I was wondering about your 2nd gear. when in 2nd, and you let off the gas, do the rpm's drop, or is there just something wrong w/ my 2nd gear. (if it is, luckily its my old tranny.)
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
