shifter install -1993
  • Thread starter Thread starter mich_427_cobra
  • Start date Start date Mar 1, 2004
M
mich_427_cobra
  • Mar 1, 2004
Trying to install shifter in my 93.
how do i remove the forward two bolts that attach the rubber boot?
there are really hard to get at under the console. any tips??
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 1, 2004
  • Mar 1, 2004
I didn't really have a problem installing my shifter...but if you are I would use a swivel of some sort or just remove the console...
What kind of shifter you installing?
David
lxsteed
1,009
Melbourne
Mar 1, 2004
  • Mar 1, 2004
I cut my console a little bit to get them out. Didn't hurt, and you can't even tell once you put the shifter trim back on.
F
Fastcat
582
St. Louis
Mar 1, 2004
  • Mar 1, 2004
I used a wrench till the screws were loose enough to unloosen w/ my fingers.
Mavrick
2,264
Collingwood, ON
Mar 1, 2004
  • Mar 1, 2004
I did the same with one of those ratchet wrenches. It takes a few minutes, just take your time. The threads arn't too long.
cobradvm
245
Woodinville, WA
Mar 1, 2004
  • Mar 1, 2004
Just two words - Dremel Tool!! Take a cutting wheel and trim back the plastic that stops you getting a socket on it - like lxsteed says - you can't see it with the shifter cover back on. Way to frustrating trying to use a wrench and do a 1/4 turn at a time.
Howard
L
leakyfaucet
273
North Carolina
Mar 1, 2004
  • Mar 1, 2004
I used a ratcheting wrench and had no problems...
mustangt93
37
San Antonio TX
Mar 1, 2004
  • Mar 1, 2004
it just takes time and patience, i used a wrench until i could get it with my fingers
BADPONYsc
884
Florence, SC
Mar 1, 2004
  • Mar 1, 2004
Same here... I've used a mini-ratchet before and I've also used a wrench. The mini- ratchet will squeeze under there, but still won't be able to turn but so much. The wrench is probably the easiest, but it will take some time turning it a tiny bit at a time. I never tried cutting the plastic away though.
HISSIN50
34
129
Mar 2, 2004
#10
  • Mar 2, 2004
  • #10
i dont know if it is what you folks meant, but i used a ratcheting box end wrench. piece of cake. good luck. hope your front shifter housing bolts (13 mm or so bolts that hold the shifter housing to the trans) are easier to get out than mine. that did require console removal.
i recommend using anti seize on the big bolts so you can hopefully get them out with the console in.
good luck.
K
Console Heat after MGW shifter install
  • KirkACola
  • Sep 24, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 24, 2025
Glad to be here
  • josep4
  • Aug 7, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
DadLife0724
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
  • dan50
  • Jul 18, 2026
dan50
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
