  • 2005 - 2009 Specific Tech
Shifter Knob Keeps Coming Loose!?!? HELP!
  • Thread starter Thread starter OBleedingMe
  • Start date Start date Jun 12, 2005
O
OBleedingMe
12
  • Jun 12, 2005
Anyone else have this problem? My shifter knob is coming out of positon, especially after hard driving. The knob is slightly off-center and I have to carefully twist it back in place. It really pisses me off, because it can screw up my shifting if it twists too far.
Do I need to spin the shifter knob clockwise to tighten it or something? Anyone have a fix for this? If I need to pop the shifter knob off, how do I do this (pull or unscrew?)?
4511.21
26
Mason, OH
Jun 12, 2005
  • Jun 12, 2005
Mines a little loose as well. It always seems to end up turned a little clockwise...with the top in the 1 or 2 o'clock position. However, I have left it that way since it fits my hand perfectly with that offset. Once it has turned to that position...it doesn't move anymore. This only started after the Triax install.
H
hurdlinmasta
85
  • Jun 12, 2005
mine 2, but its not as bad as you say it is. I think once i installed the tri-ax, it lose some grip.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jun 12, 2005
  • Jun 12, 2005
the shifter knob just screws on and off. if it needs to be tightened, rotate it until tight. i have had my knob off a few times, and i just tighten it down until it is firm and in the postion i want.
PolkThug
130
Somewhere voiding my warranty!
Jun 12, 2005
  • Jun 12, 2005
Loctite.
dcarlson
128
Long Island, NY
Jun 14, 2005
  • Jun 14, 2005
They unscrew. Counterclockwise to take it off, clockwise to tighten it. If it is a little loose, put some muscle in it and tighten it one more rotation.
Hatchman
86
Pensacola
Jun 14, 2005
  • Jun 14, 2005
Loctite, screw it on as far as you can (within reason), then back it out to straight, then let it sit overnight.
W
03 cobra shifter question
  • Wtupribs
  • Sep 7, 2025
  • SVT Tech Forum
SVT Tech Forum Sep 8, 2025
Wtupribs
W
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 10:17 PM
AlexM556
A
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
