candphall Active Member Jun 8, 2009 488 32 49 Orlando Florida Mar 7, 2010 #1 Mar 7, 2010 #1 I have a 69 Mustyang with a C6 transmission, replacing an FMX. Does anybody have any idea which shift linkage will work?
2 2+2GT 10 Year Member Apr 25, 2009 3,333 10 79 Southeastern Pennsylvania Mar 7, 2010 #2 Mar 7, 2010 #2 You can probably make the FMX rod work, but if it looks like a pain, just buy a 69 C6 rod.
woodsnake 15 Year Member Jan 16, 2007 1,352 15 69 Hicksville, NY Mar 7, 2010 #3 Mar 7, 2010 #3 Was your C6 a floor shifted car, or column?
6 68RCodeConv New Member Oct 2, 2003 345 0 0 Houston, TX Mar 10, 2010 #4 Mar 10, 2010 #4 You must have the proper shift lever AND rod to make this work. The shift lever is installed when the tranny is apart. The rod is being reproduced but AFAIK the shift lever is not and you have to find a used one.
woodsnake 15 Year Member Jan 16, 2007 1,352 15 69 Hicksville, NY Mar 10, 2010 #5 Mar 10, 2010 #5 I had to use one of these. It was probably the worst swap I have dealt with. Search Results for 418400 - SummitRacing.com
