shifter question
  • Thread starter Thread starter blue65coupe
  • Start date Start date Nov 2, 2006
blue65coupe
71
North Carolina
Nov 2, 2006
  • Nov 2, 2006
Hey guys. I have a '65 with c4 and no neutral safety. 2 questions. 1-My shifter is a little sloppy and I thought of replacing bushings and adding a neutral safety switch. How hard is it to add the switch with tranny staying in car and together? 2-If I were to change shifters, say to a B&M or something with neutral built in, what would this involve? My current shifter uses a rod where the aftermarkets use a cable. Thanks, Duane
Tim65GT
1,149
West Texas
Nov 2, 2006
  • Nov 2, 2006
The Neutral Safety switch is on the Transmission at the gear selector shaft:
Here is a link to a Mustang Monthly Article on how to rebuild your shifter:
http://www.mustangmonthly.com/howto/17398/index.html
Tim65GT
1,149
West Texas
Nov 2, 2006
  • Nov 2, 2006
Also, here is a thread that may help:
http://forums.stangnet.com/showthread.php?t=639865
blue65coupe
71
North Carolina
Nov 2, 2006
  • Nov 2, 2006
Thanks Tim65GT. How hard is it to install the switch with the tranny in the car? I know I'll have to take something loose at the tranny to install it and want to make sure I don't screw something up inside. What is involved? Also, if it is a real PIA, would I be better to go aftermarket with a neutral safety built in? AND, if so are there any pros/cons going to the cable vs. rod shifter mechanism.
Tim65GT
1,149
West Texas
Nov 3, 2006
  • Nov 3, 2006
One 1/2" nut to remove the shifter bracket from the shaft, and remove two small bolts on the switch. Then it slides off the shaft. Then install the new one and plug in the wiring and adjust the switch. See the other thread link.
No other transmission parts or items in the way.
blue65coupe
71
North Carolina
Nov 3, 2006
  • Nov 3, 2006
Thanks. I wasn't sure if the shifter bracket just slid off w/o something internal coming loose or not.
D
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Automatic Transmission questions
  • JFlagg
  • Jan 22, 2023
Classic Mustang Specific Tech Apr 7, 2023
Realmongo
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
