  • 1994 - 1995 Specific Tech
shifting issue
  • Thread starter Thread starter cbarr300
  • Start date Start date Jan 21, 2007
C
cbarr300
746
goose creek, SC
Jan 21, 2007
  • Jan 21, 2007
hey guys quick question:
I have a tremec 3550 tranny with a Hurst shifter.
I've noticed that every once in a while (like once a week maybe), I'll be cruising around in, say, fourth gear. Well, when I come to a stop light I just pop it in neutral and coast to the light. Then, when I try to put it in first it just won't go. The only way it'll go back into first is if I shift back into fourth and then run through the gears until I get back into first...then it works fine. The clutch cable is good. The pedal engages at about the halfway point. Clutch doesn't slip. Tranny doesn't really make any strange noises. Fluid was good as well.
I took the engine and trans out the car last night (rebuild for the engine) so I'm hoping that maybe it was just some kind of an alignment problem or something. Or maybe the hurst shifter is just going out on me?
Any ideas?
also, I don't know what kind of atf was in the tranny before...but I'm gonna switch it out to that gm sync mesh stuff. It is ok to do that right?
C
cbarr300
746
goose creek, SC
Jan 21, 2007
  • Jan 21, 2007
ttt
94gts
873
Carmel, New York
Jan 23, 2007
  • Jan 23, 2007
ive noticed this in a lot of stick cars i have driven, including my car. i think that sometimes when you stop, the gears just dont line up (thats the simple way of putting it). i solve it like you and just put it into another gear then it slides into first. never thought it was a big deal
C
cbarr300
746
goose creek, SC
Jan 23, 2007
  • Jan 23, 2007
eh, guess I'll just keep going with it lol. I've kinda pictured it the same way you do...about the gears just not lining up. Never really a big deal...just something I was curious about.
thanks man
95strokerPSU
986
Sacramento from Philly
Jan 24, 2007
  • Jan 24, 2007
I did a good amount of research about what to put in my Tremec and I found that some say to start with ATF and then switch to Synchromesh. But I believe I contacted Tremec and they said I'd be better off using Synchromesh right from the start. That's what I did and 7000 miles later I have no problems. So I'd say definitely switch to the GM stuff.
ProKiller
3,064
15
78
PA
Jan 24, 2007
  • Jan 24, 2007
+1 When I called up Walt at Promotion to get a clutch setup, i asked him about what I can do to my T3550. I ended up getting a TKO input shaft which is 26spline, new synch rings, new o-rings for the shift arm, and without a doubt he said get the synchromesh.
C
cbarr300
746
goose creek, SC
Jan 24, 2007
  • Jan 24, 2007
synchromesh it is then.
So no one thinks this is a big problem, right?
Thanks for all the help guys
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jan 24, 2007
  • Jan 24, 2007
Sometimes my car dosent want to to in to reverse or 1st. So I let off the clutch, press it again, and then it goes in gear fine.
slacker83
9
Pekin IL
Jan 24, 2007
  • Jan 24, 2007
I had a hurst shifter on my tko which is very similar to your 3550 and it had a issue with 3rd gear doing something like that but when I put the triax on it I never had the problem again. I made sure the stops were set correctly on the hurst and I could never get it right.
Steve
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
