Fox Shifting Problem When It Rains
  • Thread starter Thread starter moe9853
  • Start date Start date Dec 12, 2014
M
moe9853
37
San Jose, California
Dec 12, 2014
  • Dec 12, 2014
Ahhhhh!!!!!!! I need help guys. For some reason, my foxbody doesn't like to shift when it's raining. I have a 1988 5.0 lx witha manual transmission. It's a stock T5 transmission and the only mods my car has, are CAI, shorty headers, 3core radiator and lowering springs. So here's the story:
When the rain comes, my Fox doesn't like to shift. it doesn't matter what gear im in. If I'm in first going on second or second going on third, etc. Sometimes if I "double clutch" it will shift. Otherwise I sometimes just have to skip a gear altogether. It's the weirdest thing. But this only happens when it rains. On nice, sunny days, it shifts and runs great. I'm wondering if it's my clutch cable but I'm not sure. Any ideas??
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Dec 12, 2014
  • Dec 12, 2014
Well, are you having a difficulty pressing the pedal, or physically moving the shifter from gear to gear?
When was the last time you checked/changed your trans fluid?
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Dec 12, 2014
  • Dec 12, 2014
Short of having rheumatoid arthritis, what would make rain affect the systems involved in shifting? Does the clutch disc swell in high humidity?? Maybe your left knee and hip do not work as well in the rain?
I would check the cable and quadrant, and then adjust the cable for more clearance.
Reactions: jrichker
elarm1
1,428
652
154
N.Va
Dec 12, 2014
  • Dec 12, 2014
I think I know.....
Reactions: FoxMustangLvr and jrichker
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Dec 12, 2014
  • Dec 12, 2014
Could be moisture on the cable/rust causing it to shift harder. Does your car still have the inspection/dust cover on the bell housing?
M
moe9853
37
Dec 13, 2014
  • Dec 13, 2014
So I checked the fluid and the fluid is ok. I checked the dust cap on the bell housing, and it's also ok. I'm thinking I need a new clutch cable. But it's so weird, I only have problems in wet weather.and no, I don't have arthritis. I'm 22 people. Come on. Lol
jetmech807
1,195
326
164
Crestview, FL
Dec 13, 2014
  • Dec 13, 2014
Car telling you it's ready to be a sunny day cruiser only?
Reactions: 7991LXnSHO and FoxMustangLvr
addermk2
5 Year Member
Aug 25, 2009
308
87
49
Dec 13, 2014
  • Dec 13, 2014
I'll ask again since it seemed to have missed the mark the first time. When was the last time you CHANGED the fluid.
M
moe9853
37
Dec 17, 2014
  • Dec 17, 2014
Yeah I think so. Lol
M
moe9853
37
Dec 17, 2014
#10
  • Dec 17, 2014
  • #10
Depends. Lol! Haven't changed it in a few years but I've changed it about 20k miles ago. I just started driving the car again as my daily. Didn't drive it much before
tos
896
68
59
Cincinnati Ohio
Dec 18, 2014
#11
  • Dec 18, 2014
  • #11
So when its raining and you drive it around and start having the problem - Have you tried stopping the car, turning off the engine then seeing how it shifts? Does it shift ok when stopped and engine off?
Under normal conditions where does your pedal release at (where does clutch start engaging?) , Just off the floor? Or up near the end of travel (up high)?
Sounds likes maybe your clutch is getting wet and not releasing completely. Your cable is probably stretched from age and in dry/warm weather is probably just barely releasing and the moisture during rain is just enough difference in clutch friction to keep the clutch and input shaft spinning slightly.
This is an interesting problem and that's the only idea I can think of if I understand your problem correctly.
If this is the problem then adjust the clutch to engage closer to the floor and it should solve the problem.
M
moe9853
37
Dec 18, 2014
#12
  • Dec 18, 2014
  • #12
Sounds like you understand my problem perfectly. As far as I'm concerned, however, I'm not going to do anything about it. I'm planning on doing a coyote swap in the future along with an irs swap. All I'm doing how is leaving a bit earlier when I drive. Then, when it's raining (or wet outside anyway) and the shifting issue occurs, I just plull over. I press and release the clutch a couple times and it's working fine again. During the dry season, the car runs perfect.
M
moe9853
37
Dec 18, 2014
#13
  • Dec 18, 2014
  • #13
It's so weird. And the car is too old and has too many miles to try and fix it. I've decided to just deal with itfor now.
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Dec 19, 2014
#14
  • Dec 19, 2014
  • #14
moe9853 said:
Sounds like you understand my problem perfectly. As far as I'm concerned, however, I'm not going to do anything about it. I'm planning on doing a coyote swap in the future along with an irs swap. All I'm doing how is leaving a bit earlier when I drive..
Just curious but how near is the future?
M
moe9853
37
Dec 19, 2014
#15
  • Dec 19, 2014
  • #15
Not very near
Gotta save some green and find quality parts
M
moe9853
37
Dec 19, 2014
#16
  • Dec 19, 2014
  • #16
I also live in California so I have to find out about all the emission laws and stuff before I tear the car apart. Real pain when it comes to CARB
kdando87
47
#17
  • Dec 19, 2014
  • #17
Go for a one piece quadrant and adjustable cable for starters, if a coyote swap are in your not so near future then go for a new cable now, they are as cheap as cheap can get, IMO
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Dec 20, 2014
#18
  • Dec 20, 2014
  • #18
I've run into that before. The clutch disk swells a little with all the moisture. The clutch cable gets slack in it's old age and you have to take the slack out of it. The proper fix is to replace the cable and put a metal quadrant and firewall adjuster in it. If that is going to cut into your future mod budget to much I totally understand. I would hate to see that $140 keep a Coyote engine out of a real Mustang. The get buy fix is to buy a few of those fat washers from Home Depot. I believe you need a 5/8" hole, and they are about 1 and 1/4" in diameter. You remove the cable from the quadrant and pull it through the firewall Stack a few of those washers between the cable and the firewall and reconnect it. Should cost you are round 30 cents.
Kurt
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Dec 21, 2014
#19
  • Dec 21, 2014
  • #19
moe9853 said:
Not very near
So you're gonna ride around w a bad clutch or whatever until "one day!?" Often times young lad "one day" or "the future" never comes.... Fix your car
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Dec 23, 2014
#20
  • Dec 23, 2014
  • #20
Clutch cables are not too bad to replace. Get a stock replacement and enjoy the driving the car rain or shine, in my opinion.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
