Shimmy in my steering.
Bmwz389
74
I have a 93 2.3 LX (Should still be the same rack and pinion system as the 5.0)
I've had an issue ever since I bought the car. When I'm driving, the steering wheel is all over the place. I'll keep tension on the wheel since it's a little sloppy, but it feels almost like...bump steer? When I hit a bump it will dive towards one direction. I have no idea where to begin!!
I thought it had something to do with the wheels and tires possibly, but when I replaced them with an entirely new set from ford the problem still remains.
I don't know alot about rack and pinions so I'm seeking help. Any insight is appreciated!
- Brandon
Not bumpsteer, and the 4-cyl racks are different than the 5.0 racks, but they still wear out inner tie rod ends pretty religiously. They'd be the first thing I'd check, especially if you're noticing uneven wear on the front tires. Next up, check the rag joint in the steering shaft.
You should just buy a sport rack, or even better an SN95 rack. You will get new tie rods and a 2.5 turn lock to lock. The sport rack bolts right in, I did it on my 2.3L. I think you have to do a few things for an SN95 rack to work, like outer tie rods, but you can search to see what you would need. You can still turn your old rack in as a core, too, they never know the difference.
Rockauto.com has what you need. You should be able to find the stuff at your local parts stores as well. As a warning, some people have said that they did not like the feel of the parts store Fox reman racks (remanned by A-1 Cardone, among others) because they feel too light and overboosted, and therefore have decided to go with other aftermarket rack manufacturers or upgrade to SN95 units. If you are trying to find OEM stuff, I guess MPS Auto Salvage would be a good place to go. They seem to have a good reputation for used parts. I have no idea where you would find a New Old Stock Fox rack at this point.
IF you decide to upgrade to the SN95 stuff, check out these links...
http://forums.corral.net/forums/road-racing-auto-x/996909-installing-2000gt-rack-93-coupe.html
http://forums.corral.net/forums/general-mustang-tech/1168974-sn95-steering-rack-fox.html
I wish I would have upgraded to the Sn95 rack, but I didn't know any better at the time. Maybe next time :(
How much slack are in the tie rod joints and universal & flex joint steering shaft couplers?
The universal and flex joint steering shaft couplers can be inspected with the car parked on the ground. With the engine off, have a helper rock the steering wheel back and forth while you inspect the universal and flex joint steering shaft couplers for excessive slack. You'll need a sharp eye and a strong light to do a good job.
Support the car on jackstands with the jackstands placed as close to the wheel as possible. With the steering locked, have a helper try to move each front wheel just like it would move if you turned the steering wheel. While they are rocking the wheels, you are under the car watching for slack in the tie rods.
[b[Steering rack replacement[/b]
The two inner tie rod ends are usually what wears out, and at $45 each, it's better to get a replacement rack assembly since they are part of the package. The rack is about $100 + a $40 refundable core charge, which you get back when you return the old rack. Be sure to ask for the GT or high performance rack, it has fewer turns lock to lock than the standard rack.
The flex coupling for the steering shaft needs to be disconnected before you can get the rack out. You should disassemble the coupling by removing the 2 bolts that hold it together. The lower part of the coupling will then come out with the rack, and can easily be removed.
The tie rod ends can be removed with a tool that looks like a giant "pickle fork", it's less than $8, or some stores will rent/loan one. Remove the cotter pin & nut on the tie end, stick the tool between the rod end and the arm it connects and hammer away. The bigger the hammer, the easier it comes apart.
Remove the two bolts that bolt the rack assembly to the frame and then pull the rack down. Get a catch pan to dump the fluid in when you disconnect the hydraulic lines. I replaced the rack mount bushings with some Energy Suspension urethane ones. When you re-install the rack assembly, put the rear bushings in the rack assembly and lift it into place. Then install the hydraulic lines, front bushings & washers and tighten down the nuts. Doing it this way makes room for the hydraulic lines without having them bind against the frame.
To change the tie rod ends, do them one at a time. Loosen the jam nut 1/4 turn, then unscrew the tie rod end from the rack. Turn the jam nut back 1/4 turn to return it to its original position. With the tie rod end removed, use a machinist square to measure the distance between the end of the threaded rod and the jam nut. Sit the bottom of the square against the end of the threaded rod, and the end of the blade of the square against the jam nut. Duplicate the measurement on the new rack and then install the tie rod end and tighten the jam nut. Then do the other side: the front end will need aligning, but the toe in will be close enough to the setting of the original rack to drive.
Buy several extra quarts of fluid to run through the system to flush it when you change the rack. The car needs to be up on jackstands for the next step. Fill the pump up, start the car, and turn the wheels lock to lock to bleed the air out. Then stop the engine, disconnect the low pressure hose (the one that is secured with a hose clamp) and drain the pump. Re-connect, refill and do it several more times or until the fluid looks clear and not burnt or black.
Power steering pressure lines:
Each hose uses an O ring on each end to seal them. The hoses will swivel when they are installed and tightened into place. That is why there are O rings on the fittings. The O ring is the part that actually makes the pressure seal. If you slide the nut all the way back as far as it will go, you will see the O ring and the groove cut into the center section of the fitting.
attachment.php
Sometimes you will get some white Teflon rings with the pump or rack. The rings go on the threaded part of the fitting to reduce or prevent small leaks. They are not meant to seal the pressure part of the line or substitute for the rubber O ring. Heat the white Teflon seals in hot water and they will be easier to install. You can install the fittings without them and not have any leaks if the O rings seal good.
I just went through this exact problem. I converted everything over to manual steering. I bought a quick ratio rack and pinion came with an upgraded shaft, inners and outers and the difference is night and day. Great road feel, quick turn all around the best handling. My car used for mostly wkends car shows and track days. Not sure if manual will suite your needs
I would love to upgrade to the SN95 racks, however this is just a daily driver that I'm trying to keep my pockets light with, so I won't be spending 200+ on a hybrid steering shaft haha. The remans aren't pricey at all, and I for one don't really need the heavy feeling of real road on such a slow vehicle. I think that might be the route I go. If I replace the inner tie rods I'd need to out tie rods, bushings and boots with it I presume, which would total the price of a new rack. I just know when I go to sell this, whoever feels this steering all over the road will deem it unsafe. I can be a pretty risky driver, but that steering is scary!
Thank you all for the prompt replies. I will follow up with what I end up doing!
- Brandon
Another thing to my last post. These new o-rings on the pressure lines, do they have rings on the lines off the power steering pump? I have a slight leak from the pump at the lines, and that would explain it.
- Brandon
