teebluestang Member Jan 30, 2016 57 3 8 Sewell N.J Sep 22, 2018 #1 Sep 22, 2018 #1 Has anyone used Scott fab. Shock replacement? Anyone ever weld in their own metal towers from local metal yard, if so what gauge did you use ?
Davedacarpainter Chicks can make things hard if they’re inspired... SN Certified Technician Nov 28, 2015 11,833 11,634 203 Discordia Sep 23, 2018 #2 Sep 23, 2018 #2 I’ve replaced the lower part when I repaired the rust on mine. Scott Rod offers strut towers now? Or are you talking about the shock towers in the rear of the car? Strut tower is 16 gauge.
teebluestang Member Jan 30, 2016 57 3 8 Sewell N.J Sep 23, 2018 #3 Sep 23, 2018 #3 I'm talking about the front strut towers.
teebluestang Member Jan 30, 2016 57 3 8 Sewell N.J Sep 23, 2018 #4 Sep 23, 2018 #4 http://scottrodfab.com/shop/fox-body-mustang/168-fox-frame-railstrut-repair-kit.html
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,349 18,085 224 Massachusetts Sep 23, 2018 #5 Sep 23, 2018 #5 Scott rod has these http://scottrodfab.com/shop/fox-body-mustang/168-fox-frame-railstrut-repair-kit.html But I wasn't aware they did the whole tower. I can't find it
teebluestang Member Jan 30, 2016 57 3 8 Sewell N.J Sep 23, 2018 #6 Sep 23, 2018 #6 I'm wondering if I should have someone cut out good shock towers from their parts car. Or just weld in new metal .. if welding new metal what gauge would it be ? Front towers are shot
Davedacarpainter Chicks can make things hard if they’re inspired... SN Certified Technician Nov 28, 2015 11,833 11,634 203 Discordia Sep 23, 2018 #7 Sep 23, 2018 #7 That will work fine if that takes care of your rotting area. I replaced my entire right side frame rail and used a sheet of 16 gauge steal for the shock tower repair. The frame rail is 14 gauge. This is the kit I used. https://lmr.com/item/LRS-FRRN881/1979-93-Mustang-RH-Smooth-Frame-Rail Reactions: teebluestang
