short block storage ?
  • Thread starter Thread starter 88stangmangt
  • Start date Start date Apr 3, 2004
88stangmangt
2,332
Stafford,VA
Apr 3, 2004
  • Apr 3, 2004
My dad says i should not take apart my engine yet until i have everything to put it back together because he said it will get rusty. i am talking maybe 2 months at the most before i get my afr heads and i wanted to paint the block and hone it when i am ready. but i am bored so i want something to do so will it be a problem?
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Apr 3, 2004
  • Apr 3, 2004
tranny fluid or wd40 on a reg basis will preserve it just fine
88stangmangt
2,332
Stafford,VA
Apr 3, 2004
  • Apr 3, 2004
well as long as i didnt hone it untill i was ready to pt everything back together it would be fine right? and i guess the crank and piston heads are safe anyway right?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Apr 4, 2004
  • Apr 4, 2004
just lube it all up and keep it lubed it wont rust.
D
Demented4.6
1,055
DAYTON, OHIO
Apr 4, 2004
  • Apr 4, 2004
i was always told to spray it down with WD real good and out a plastic bag around it. WD 40 stands for water displacement so you wont have any issues of rust if water can't penetrate. then when you go to assemble the motor wipe it down ( i washed mine thoroghly and re applied some oil ) and your done
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Apr 4, 2004
  • Apr 4, 2004
I've had the motor from my '85 sitting on a stand since November. The bottom end is together but no heads, intake or oil pan yet.
I just spray it with WD-40 and put a trash bag over it. No rust at all
NKau
1,346
Jefferson, WI
Apr 4, 2004
  • Apr 4, 2004
Just do as everyone said with the WD-40 on a regular basis, and you'll be fine. Just be sure to keep a trash bag or something over the motor, and put the crank in an air-tight bag if at all possible to keep moisture and crud off it after spraying it down with WD-40.
88stangmangt
2,332
Stafford,VA
Apr 4, 2004
  • Apr 4, 2004
right on i am prob gonna do that then prob after i get done relic hunting.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
