short throw shifter????
factory shifters should have a rubber grommet. I took mine off and it leaves like a 3/4" hole. so thats a way you could tell. Look at your shifter in first gear, if its factory it will be level with the AC knobs, maybe even higher.
A picture of the shifter handle is required. If you have the boot / shifter bezel off there might be an inscription of the brand on the handle. Also is the NVH grommet still in place on the trans tunnel? Does it look like it has been tampered with at all?
My Steeda shifter is aluminum and much stiffer than the stocker it replaced. I can take a photo of the stock unit tonight and post it for you to compare to.
Yeah, actually even the worst aftermarket shifters I've seen still have a nice, precision appearance; whereas the stock shifter has a cheap, crappy, cast garbage "just enough to get the job done" look. We'll need to look to see which brand it is, but seeing if it's stock or not should be a no brainer.
ANYTHING is better than stock. That's hardly a fitting way to describe a Pro5.0- easily one of the best shifters you can get. THE best, in my opinion- but between the top two (Pro5.0 and Steeda Tri-Ax) the best is really user preference. That may be top three soon, as the MGW piece is generating some great reviews, but it isn't in anywhere near enough cars yet to be on that pedestal even if it deserves it. Regardless, rest assured that if you have more than just the shift lever, you have the one prefered by more class winning drag racers (of Mustangs AND F-bodies) than any other shifter made.
My mom took my car for a ride as soon as I brought it home from buying it. She came back all white and shaky and said "should I kiss you good buy now or later that thing is fu-ckin fast". And to this day she won't drive it. But my Dad likes to steal it on me and is thinking about looking for one.
As long as he brings it back with a full tank let him take it when he wants.
