shortblock vs longblock
  • Thread starter Thread starter 1991vert
  • Start date Start date Jul 18, 2005
1991vert
1,103
Ludlow, MA
Jul 18, 2005
  • Jul 18, 2005
what's the difference between a 306 shortblock and a 306 longblock?
i was looking at a 306 CHP, but didnt know which one is better.
are CHP's better than dart blocks?
stang_dan
172
new jersey/north caroline
Jul 18, 2005
  • Jul 18, 2005
306 short block is just the block no heads
306 long block is the block with heads and such
most of the chp block are stock blocks which are machined and such
dart is a stronger block alot more money tho i dont knowif dart rebuilds blocks tho.
dan
GRGT1994
1,034
  • Jul 18, 2005
The short block comes with the bottom end stuff (crank, pistons, rods, etc.) installed. A long block is the same as a short block plus heads, pushrods, rockers, cam (I think).
So neither is really better. Just depends on what u want. If you have good top end stuff that you plan to reuse, then you can go with the short block. If you want all new stuff, then go with the long block.
Daniel50
716
Discovery Bay, CA
Jul 18, 2005
  • Jul 18, 2005
yeah short block. comes with the engine block, rods, pistons, crank, and all the other little bearings, rings, and goodies. and the long block adds the heads, valvetrain, rockers, pushrods, and basically everything from the valve covers down
1991vert
1,103
Ludlow, MA
Jul 18, 2005
  • Jul 18, 2005
gotcha, never really knew the difference. i thought it was just called a crate engine when you only have to add induction.
thanks for the heads up. going with the dart and novi 2000
GRGT1994
1,034
  • Jul 18, 2005
A crate engine is even more complete. It includes the intake too. Pretty much a plug and play way to go.
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
K
Mustang tire size
  • Konstang
  • Jun 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
revhead347
