  • 1994 - 1995 Specific Tech
Should I lower compression?
  • Thread starter Thread starter pwcracer
  • Start date Start date May 9, 2005
pwcracer
347
Hastings, MN, USA
May 9, 2005
  • May 9, 2005
I am replacing the head gasket in on my car and switching over to a set of ported GT40's at the same time. Due to the supercharger, would it make sense to go with a thicker compressed gasket to try and lower the compression ratio? I was thinking something around .050... I also have lame stamped steal rockers, does it make sense to swtich to rollers with a stock cam?
Killercanary
The car that set the bar.
Altoona, PA
May 9, 2005
  • May 9, 2005
I'm not a power adder guy, but you will make more power WITH compression and boost than low compression with boost IF the tune is on and detonation is avoided. If you don't plan to turn the boost way up and the compression won't be much higher than 9.2:1 then I'd leave it alone. Running thicker head gaskets have a negative effect on quwench from what I've heard, but you'd have to chekc the power adders sections for more info on that.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
No start
  • dkrupp79
  • May 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2025
dkrupp79
D
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
