Should I replace my rack???
noclue02
15
Ok so I posted a thread about my front end squeking on my car a couple weeks ago. I have figured exactly where the squeaking is coming from. It is on the passenger side of the rack and it is internal well from what I can tell. I was feeling the boot and it feels like there is some kind of ball joint on the end of the tie rod. Is this correct? also is there something else I can try before replacing the rack? I gotta get rid of this squeak!!!:eek: BTW it is an 02 model with 140k on it. Any help would be appreciated.
TSB 05-14-3 SQUEAK/CREAK NOISE FROM STEERING
There is a Ford TSB about your problem. The noise usually happens at the limits of travel.
The Ford fix is to replace the steering rack support tubes and through bolt.
I fixed my 03 by switching to denser rack bushings and lubbing with lithum grease.
TSB 05-14-3
07/25/05
SQUEAK/CREAK NOISE FROM STEERING RACK WHEN TURNING
FORD:
2002-2004 Mustang
This article supersedes TSB 04-24-8 to update the Action.
ISSUE
Some 2002-2004 Mustang vehicles may exhibit a squeak or creak type noise when turning.
ACTION
Replace both power steering gear tube brackets.
Refer to Workshop Manual Section 211-02 Steering Gear Mounting. Tighten the steering gear mounting fasteners to 52 lb-ft (70 N.m).
