Should I trade stangs??
NOLA_SVT
Ok I will have to post this in two different sections just to get fair feedback...
Should I trade my 1995 Mustang GT:
Good:
306 with about 4,000 miles on a freshened up motor (rebuilt heads, new bearings and rings, all premium gaskets, all new bolts washers and nuts, new water pump, oil pump, oil pan, thermostat, belts, hoses)
New rack and pinion/Tie rods
New Altenator and Battery
Holley Heads
MSD 6AL
MSD Blaster Coil
MSD ProBillet Distributor
Eddlebrock Upper and Lower
BBK 65mm Throttle Body
EGR deleted edlebrock elbow
Cold air intake/K&N Conr Filter
Phenolic Manifold Spacer
Chrome Valve Covers
Heat-wrapped BBK Longtubes
Full 2.5" exhaust
24# Injectors
ProFlow MAF
4.10 Gears
Tremmec 3650
Zoom Stage 3 Ceramic Cluth with stock replacement flywheel
Unknown cam
TweecerRT Tuning
Decent Interior
Aftermarket Sway bar
New Nitto 555R's on back
Bad:
faded bumpers and taillight trim
NO A/C
Bad Mounts (engine and transmission)
Very Notchy Shifting
Needs Alignment
Needs struts/shocks bad
Needs to be dyno tuned
SLOW only runs 13.80 @102 with everything above
For a near bone stock 2000 GT Bright red, flawless paint, convertible with a/c 109k on the clock
i wouldnt.....it seems like you will regret it in the future, and judging from all the mods you have done to it, it seems like you have a long history with the car. and when you think about it, theres not THAT MANY performance mods. also, its a 95 GT.....those are becoming rare to stumble upon.
Id say keep it. With all that work and energy into it you'll regret it later. Just spend a few bucks and fix whats wrong with it. And +1 for it being a 95, those are becomming rare. I'd like to fing one someday
Well I guess that idea is dead... I think when I actually made the list and realized everything I had invested into the car is when I decided for myself... case closed...
I think right now I am just disgusted with the car because it has become my daily. I recently moved to go to school and all I have now is an apartment while I had a beautiful garage and all my tools back home. The car gets 10 mpg at best, is terribly slow for all thats done, doesn't run the smoothest cause its in need of a good tune, has no a/c or heat requireing a dash pull.. It drives like an absolute boat, I haven't gotten it aligned because it needs struts/shocks and I would also like to get camber/caster plates first. But money has been super tight and my beater is in need of a new engine... Just disgusted with it but I know I will regret just not holding out and getting it right...
So the only reason I even entertained the idea of a trade is because the other car would be much more street friendly, better milage, a/c, flawless paint, and CONVERTBLE... Thats it, only reason it crossed my mind...
Thanks for letting me vent and convincing me not to do anything rash...
