Should I use aluminum or steel pistons
pineapple
Chicago
My 5.0 needs a new rebuild and I am looking to make it really fast. I am wondering which are better steel or aluminum cylinder heads. Which one operates at a higher temp, etc. I know that steel is stronger at higher temps, but aluminum displaces its heat better. If you could get back to me I would appreciate it thanks. :spot:
Oh here we go....
It depends on what you want to go with your entire combo. That said, it also depends on what brand head you would like to go with as it may limit whether you even have the choice of iron and/or aluminum.
People go fast with iron GT40P's.
People go fast with alum AFR's.
People don't go fast with paper mache' heads.
Are you leaning towards any specific brand?
Edit: DO A SEARCH.
Heads
I, myself, prefer steel (iron). However, not many companies are making iron heads anymore. Pretty much all the top heads are aluminum. So if you have the money for a class of head like a TFS, AFR, Edelbrock, etc...etc...you pretty much have to buy aluminum anyway. Your only other option is to buy older heads or buy an "ok" head like a GT40 or Dart and have them ported. It depends on the type of set up your going with too. Its hard to beat an AFR 165/185 or a twisted wedge head for a steet application.
Just my opinion....
i think that the aluminums decipate heat better, but the irons are stronger. aluminum weighs less.
like said before, pick a whole combo. heads can almost be last in some cases. A lot of it depends on the cam, injectors, etc etc.
