- Aug 11, 2003
- 297
- 0
- 0
Someone told me a long time ago that it's good to set the A/C to the off position before turning off the car, otherwise you could eventually cause damage (to the a/c not the car) if you start it and it's on. True?
Starting the car with the A/C on also puts extra strain on the starter motor. To me, it's just good habits to turn everything off before turning off the car - and starting the car with no accessories on.vidmaster said:if you crank the engine with the a/c on, it will eventually blow the compressor. thats why i always turn my key first without starting it. lets the fuel system pressurize and i also get to turn the a/c off if i left it on![]()
Marks5.0! said:ive made it a habit to turn mine off when i get out of the car
merc123 said:I knew a guy in high school that left his a/c on and shut off his truck. His amp shorted out because of bad wiring and the truck kicked over and turned on the blower. It blew the fire into the cab of the truck and burned it down.
hognutz said:there is no techincal merit behind this bs if you really think about it. when you turn the key to activate the starter power is cut for the ac/accessories so it does not have to compete for power. hence the clutch is not engaged. once you turn the key back from the start position then the power will make it to the clutch and the ac unit. then motor will then be running though.
