Ok so now I'm not sure if it is too far out or two far in. Like I said when you start the car the crank pulley immediately pulls the belt out all the way to the front of the car making me think that it's too far in and needs a spacer or something. However, when it pulls itself out on the crank and its still where it should be on the other pulleys and you look at it from the side the crank is definitely pulling it at an angle forward as compared to the alternator, which would make you think that the crank is too far out. This probably sounds like a bunch of jibberish. I guess what I am saying is visually it seems as if the pulleys are lined up as is, but I don't get why it is pulley the belt out on the crank pulley making it NOT line up with the others. Any help would be great.
