  • SN95 4.6L Mustang Tech
Sick Computer?
  • Thread starter Thread starter Boosted92LX
  • Start date Start date Oct 3, 2012
  • 3
1 of 3 Next Last
Boosted92LX
5,721
4,244
224
Oct 3, 2012
  • Oct 3, 2012
What a way to start... Bought my first SN95 last Friday. 97 GT. Ran beautifully, was very pleased with it. It did throw a CEL on the way home, and I stopped at an auto zone to get a scan. Only code was insufficient catalyst. I figured the high flow cats just weren't doing enough and MIL eliminators would solve that...Still ran fine. I don't know if it was coincidence or not, but drove it in an incredible rain storm the next day and it hasn't been right since. Intermittent dead miss. Rough idle that comes and goes. Threw more codes, P0153- o2 slow response, p0420-bank 1 catalyst below ... p0430- catalyst below bank 2, p1150 lack of ho2 switches fuel at trim limit. p1152 lack of " " sensor indicates rich.
I removed plug wires to check for water, found none. Replaced coil packs with spare set, car ran better for 30 minutes... miss came back. replaced plug wires with good wires. (also spare) Miss went away for about 30 minutes, this time CEL cleared... then came back along with the miss.
What's bad about all of this is the engine problems come and go. Anytime I've ever had a bad o2 sensor the car ran bad ALL THE TIME. I just went through this crap with my fox, changed o2's, plugs, wires, etc etc all the while the codes were telling me I had o2 sensors out, and it wound up being a bad pcm. Replaced that and it ran like a new car. Just like my 97, the problem was intermittent.
So, past experience tells me to replace the pcm, codes tell me to replace o2 sensors. Thoughts or suggestions?
EDIT: Jacked the car up and disonnected all of the 02 sensor connections looking for water. Found none, sprayed connections and reconnected. No change.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
  • Oct 3, 2012
Check the puter make sure no water there? Maybe water leaking in somewhere.
Clean the maf meter
Boosted92LX
5,721
4,244
224
Oct 3, 2012
  • Oct 3, 2012
You know I thought about that for about 5 seconds, then thought naw, no way. I'm going to check it and see, I guess.
5.0Droptop said:
Clean the maf meter
I'll try this.. but wouldn't it cause continuous problems as opposed to intermittent?
BTW, thanks for replying Shawn. Hope you get to feeling better, bud.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
  • Oct 3, 2012
Does it have a in fender air filter on the end of a cold air kit? If so check the filter as well.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
  • Oct 3, 2012
Hard to say. The computer can compensate but if it swings from one extreme to another it cannot keep up.
Boosted92LX
5,721
4,244
224
Oct 3, 2012
  • Oct 3, 2012
It's got a BBK CAI with a K&N in the fender. Will check..
Boosted92LX
5,721
4,244
224
Oct 3, 2012
  • Oct 3, 2012
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
  • Oct 3, 2012
If the filter is wet that could slow air flow. i would think that could cause issues.
The sensors read rich. Lack of air flow.
Dirty maf
Maybe a sensor.
Reactions: SSeater
Boosted92LX
5,721
4,244
224
Oct 3, 2012
  • Oct 3, 2012
Agreed, but it's had 5 days to dry out. I'm thinking maybe just dirty, then on top of that maybe wet kicked the whole thing off? I did pull plugs and look at them. amazingly they're not fouled.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
#10
  • Oct 3, 2012
  • #10
You will find it.
Boosted92LX
5,721
4,244
224
Oct 3, 2012
#11
  • Oct 3, 2012
  • #11
I'll check that maf tomorrow and buy a cleaner/oil kit for that K&N... Good direction. Thanks Shawn.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
#12
  • Oct 3, 2012
  • #12
I hit a huge puddle one time and it killed the wideband sensor in my wife's car.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
#13
  • Oct 3, 2012
  • #13
Mske sure you follow the directions on oiling the filter. People tend to over oil them and not let the filter sit as instructed and then the oil fouls the maf.
Maybe the filter was really dirty and got wet the crusted up.
Boosted92LX
5,721
4,244
224
Oct 3, 2012
#14
  • Oct 3, 2012
  • #14
It's gotta be on the intake side. No way 4 o2 sensors all go out at once.... although that would be my luck.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
#15
  • Oct 3, 2012
  • #15
That was my thought process as well.
But I've been wrong before.
*waits for someone to post a book of things to check*
Reactions: SSeater
Boosted92LX
5,721
4,244
224
Oct 3, 2012
#16
  • Oct 3, 2012
  • #16
I'm out- good night!
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 3, 2012
#17
  • Oct 3, 2012
  • #17
Later mang.
ChuckStyles
Banned
Sep 29, 2012
51
San Diego, CA
Oct 3, 2012
#18
  • Oct 3, 2012
  • #18
I worked on a few of these cars over the years and I'd check the intake tubes running from the main tube to the plenum.
Did you look underneath the car? Had a friend install an aftermarket midpipe and he didn't zip tie the o2 sensor wires so the insulation melted and screwed them all up.
Boosted92LX
5,721
4,244
224
Oct 4, 2012
#19
  • Oct 4, 2012
  • #19
Yeah i checked the wires under the car for damage, they were good. Will also look at intake tubes, thank you!
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 4, 2012
#20
  • Oct 4, 2012
  • #20
Did you check your tach gear. Ive seen them wear down and throw the computer off.
  • 3
1 of 3 Next Last
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
  • brandyn200
  • Jun 20, 2026
AeroCoupe
