side emblems
x2cstang said:
Here at the body shop we use fishing line and run it underneath the emblems. Then all you need is some adhesive remover and it will clean right up. If you use 3M adhesive remover get the one that is NOT in the spray bottle. :nice:
thats the way i have heard...but do you know if mustangs are like the F150 emblems with two holes in the quarter panel to line it up right?
I've seen plenty of debadged mustangs running around and none of them have the holes to line them up...I will second the recommendation for the fishing line (or some similar)...then it just takes some really high pressure hot water or an adhesive remover...I've done this on other cars and the adhesive is a bit of a pain in the a$$ so plan on using some elbow grease
