The wire broke on the + side of my coil wheni tried to put new coil on.
It broke right the L shape. Can this be replaced or would it work just as good to get some stakon (hope i spelled that right) and use the nut and washer that came with the new coil?
You really can't replace the L without another splice or a new engine harness. The stakeon connector, as you described it, is a cheap solution that will work fine.
