Silly Cylinder Balance Test Question
66COUP
9
Howdy y'all. I have a silly cylinder balance test question...is it normal to get mixed results on a slightly modified car (1989 5.0 LX 5 speed)?
I built the engine last year and only have 3,500 miles on it - it had been running great until my second new Motorcraft TFI module went out two weeks ago. I ended up finding a NOS TFI module on eBay and the car seems to be running great again. I drove it around for about 45 minutes and decided to do the KOEO / KOER / CBT tests. KOEO flashes 11, KOER flashes 94 & 44 (smog pump removed and lines plugged), and CBT 8 3. I ran the CBT a day later after a bit of driving and got 6 4 2. I ran the test in its 2nd iteration and got 8 7 6 3 2.
The block is from 2002 mountaineer that I had a local machine shop work on for me. Its .020 over with all new bearings, gt40p heads, tfs valve springs, tfs1 cam, tfs 6.300 pushrods, scorpion 1.6rr, frpp lifters, explorer intake, 19lb explorer injectors, gt40p heads, 65mm tb, 70mm maf from a 95 cobra, frpp headers, bassani catted x pipe. All of this stuff was brand new out of the box - even the explorer heads/intake/injectors. I even installed all new sensors, screamin' demon ignition coil, livewires, nos motorcraft distributor, taylor cap/rotor, frpp water pump, etc. I bought all new stuff because the stuff it replaced was 20+ years old and had 466K miles on it when the old crank/block broke because of a bad thrust bearing.
The spark plugs look great, vacuum at idle is 13.5, idle is at 850 rpms, and timing is at 12 degrees. I have checked the salt/pepper shakers and all of the engine grounds. I am not sure where to go from here. I know it sounds crazy, but even with it running good it bothers me knowing that the CBT is returning all of those cylinders and not a 90.
Any words of wisdom?
I believe it monitors RPM only, and not emissions output via the o2 sensors.
Basically the test idles up the engine and turns off one fuel injector at a time. It looks to see fluctuations (drop) in idle to confirm the cylinder gas cut out, and then returns when the injector is activated.
It's a very crude way of detecting misfires, and i believe if a cam is lumpy enough or the idle is choppy and unstable you can get false readings.
Reactions: 90sickfox
I've got first hand experience.... The balance test is not accurate on a cammed car. Chased my tail for months about 15 years ago because of it.
For the TFI, are you using the white cooling paste or the kinda clear dielectric grease ? The only place I could find the correct paste was at Autozone. Advance Auto doesn't carry it at all...and their TFI comes with dielectric grease. I know you used motorcraft....just wondering.
This post has a good explanation: https://www.stangnet.com/mustang-forums/threads/cylinder-balance-test.695039/
Essentially tests are run on each cylinder independently to determine if there is something wrong with the power output of the cylinder - typically ignition or fuel related.
I'm the guy that created the original tech note on cylinder balance. test. That particular tech note is over 10 years old and has been updated and modified several times. See below to get the latest revision.
Cylinder balance test: use this to find dead or weak cylinders:
Revised 09-Sep-2017 Added reminder to write down the stored codes and engine running codes.
The computer has a cylinder balance test that helps locate cylinders with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, have the clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you dump the codes and then you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Order it at Walmart for a better price and free shipping
Write down the codes that the computer outputs since they will give you information on problems that are stored in the computer's memory
If you have idle or IAC/IAB problems and the engine will not idle on its own without mechanically adjusting the base idle speed above 625-750 RPM, this test will fail with random cylinders pointed out every time it runs. The IAC/IAB must be capable of controlling the engine speed to run in the 1300-1500 RPM range. Playing with the base idle speed by adjusting it upwards will not work, the computer has to be able to control the engine speed using the IAC/IAB.
Fail to have a stable idle that is controlled by the computer and you will get random cylinders that fail for no reason. Again, playing with the idle stop screw to get the car to idle INSTEAD OF HAVING THE COMPUTER DO IT is so bad that it is like having BOZO the clown work on your car. DON'T DO IT!!!
Warm the car's engine up to normal operating temperature. With the test jumper in test position, start the engine and let it stabilize. It should flash a 10 and then a 4 and maybe an 11. If no 11, then there are other codes that will be dumped.
Write down the codes that the computer outputs since they will give you information that the computer found when it is running. These are often different from the stored codes.
One of the first tests it does is to open the EGR all the way, this will cause the engine to stumble and almost die. If the engine dies here then you have EGR problems.
To start the cylinder balance test, briefly floor the accelerator past 2500 RPM and let off the accelerator. The engine will stabilize at about 1300-1450 RPM and the cut off the fuel injectors one at a time. The engine speed will drop briefly and the computer will turn the fuel injector for the cylinder under test back on. Then it starts the process for the next cylinder. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
See
View: https://www.youtube.com/watch?v=HDXrkKS4jTE
for a visual tour through the process. There is no voice narration so you have to listen carefully for the engine sounds. I posted the link for the benefit of Stangnet members who had questions about how to do a cylinder balance test. I do not own that video and I am not the creator.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent/loan. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :D
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 250,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
Reactions: RangerJoe
What to expect:
Alternate methods:
See
Thanks for the latest info jrichker. So is what I am experiencing expected with a TFS1 cammed car? I have no idle/stall problems or any drivability issues.
I used the white paste from Autozone. None of the last 3 motorcraft tfi's came with the paste. With this most recent change to the NOS motorcraft part, I used Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound https://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
It sure seems that way to me. The only piece in there that I caught was that if you have multiple or irratic cylinders failing, then it could be a central ignition issue like a coil, cap, rotor, or ignition box. However, those would likely manifest themselves through other symptoms. So, I think the fam explains what you're seeing.
I learned a lot reading this thread, and though I doubt that my Big Stuff 3 has a cylinder balance test capability, I wonder if I could replicate the test by pulling injector plug wires one at a time while I listen for an audible idle pitch change. Then pull spark plug wires with an insulated tool one at a time while listening. I would also think a fresh set of plugs would give you something visual to inspect to see if a cylinder is working properly.
