Simiple and cheap ignition setup? Suggestions?
1993SSP
1,194
Ky
Right now I have a project car, it's an 86 model car, but has a fresh rebuilt engine in it from a 1991 5.0. The ignition I have is a duraspark that came from a 85 model that is a non roller motor. Can I use this setup with my engine or should I look into a new ignition?? I know there is a difference between the gears on the distributors between roller and non roller but I cannot remember which will work and which one will not.
ignition
i bought a competition electronics dist. 12 volt plug and play, they have them in models from 80.00 up..... uses your exsisting coil, hook up 12 volts and its running. you may check ebay for the same dist, 60.00 cheaper there and it comes from the same place......
