Simple question, please help
  • Thread starter Thread starter MYLX5.0
  • Start date Start date Jul 30, 2005
M
MYLX5.0
93
Dover, DE
Jul 30, 2005
  • Jul 30, 2005
How many wires are going into the Self-test Connector to check for codes? When I got the car there was 3 wires going into it with another one just hanging there, so I put it into one of the ports, but I think it was in the wrong port because when I took my car to get tested, their tool diagnostics tool wouldnt connect right. Could somebody please tell me which color wires go into which port?, PLEASE.
Again, PLEASE, anybody with a 5.0 could help me, Thank you all
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 30, 2005
  • Jul 30, 2005
Diagram courtsey of Tmoss & Stang&2birds. Look to the upper LH side of the diagram for your answer...
M
MYLX5.0
93
Dover, DE
Jul 30, 2005
  • Jul 30, 2005
Okay, so there are supposed to be 3 wires, so what did that other wire go to? It is coming out of the same spot the other wires are and fit right into the plug.
M
MYLX5.0
93
Dover, DE
Jul 31, 2005
  • Jul 31, 2005
Bump bump
M
MYLX5.0
93
Dover, DE
Aug 1, 2005
  • Aug 1, 2005
Somebody has to know this, PLEASE
I just got it back from another shop and he couldn't get any codes from it either.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 1, 2005
  • Aug 1, 2005
All you need to get codes out of the computer is a paper clip jumpered between the white/red wire (#48) and the black/white wire (#46). The white/red wire (#48) is a short pigtail off of the big connector.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
If you have all the wires identified and then jumper them and don't get any codes, then one of the wires is broken.
With the power off, measure the resistance between the black/white wire (#46) and battery ground. You should see less than 1.5 ohms, more than 1.5 ohms and you have a broken wire or bad connection.
At this point unless you have a DVM or multimeter and some electrical smarts, you need to find someone good with electrical circuits. It is very difficult to get someone enough training to troubleshoot electrical problems by way of Stangnet.
If you have the tools & electrical training I will be glad to help. If not, then this is going to be very difficult for you.
M
MYLX5.0
93
Dover, DE
Aug 2, 2005
  • Aug 2, 2005
I don't see a white/red wire. There is a tan/red wire with a female connection on the end coming out of the same wiring bundle as the Self-test connector. Next to that in another bunch of wires is a tan wire with a female connection too but with a brown plug on the end of it.
What is going on here?
Saleen0679
876
24
49
Yakima, WA
Aug 2, 2005
  • Aug 2, 2005
The tan/red wire is the same as the red/white STI wire in the posted diagram. Mine is tan/red also, with a grey connector. You can also reference #48 on http://fordfuelinjection.com/?p=6
M
MYLX5.0
93
Dover, DE
Aug 2, 2005
  • Aug 2, 2005
Okay, thanks a bunch. Mine doesn't have any plug on it, it is just a straight up piece of metal connector, is this normal?
I guess now would be a good time to mention that I hooked up the tan wire with the plug on it to the black/white wire and it sparked and every since then I have had a check engine light on. Any ideas what I did?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2005
#10
  • Aug 3, 2005
  • #10
Disconnect the battery for 20 minutes. If that doesn't fix it, you shorted the check engine light circuit inside the computer. I hope that you have a spare computer around, because that's the only way you are going to be able to fix this problem.
M
MYLX5.0
93
Dover, DE
Aug 3, 2005
#11
  • Aug 3, 2005
  • #11
Well it's a damn good thing that I have a new EEC sitting around in my pantry. This sucks a fat one.
Thanks for the help.
Saleen0679
876
24
49
Yakima, WA
Aug 3, 2005
#12
  • Aug 3, 2005
  • #12
The STI connector originally came with a platic shell around the terminal pictured here.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
