Simple Upgrades?
gregsmy
30
I am building a 36 Ford street rod truck that has the 5.0 HO engine and trans from a 87 Lincoln Mark VII LSC. It has an aftermarket "Painless" wiring harness for the EFI and has been changed over to MAF. Everything else about the engine and trans are stock. Are there any simple and inexpensive bolt ons that would improve power or fuel economy? I am not looking for any high horsepower gains, just interested to see if there are things I can do that would improve the performance or gas mileage. Things I have looked at include a new chip for the ECM, larger throttle body, and a shift kit for the trans. I figured I would ask here to see if those would be a waste of time at this point or if there are other areas to look into. Thanks
a/c delete, underdrive pulleys, electric fan, and a set of headers will be the cheapest things you can do the motor. 3.73 or higher gears in the rear will help with in town mileage and give you good seat of the pants feel down low.
I am running headers with a new 2.5" exhaust system and no catalytic converters. So far stock accesories including a/c, pwr strng, and alternator. Will probably be running a electric fan due to limited clearance problems.
Need to figure out how to decode the diff tag to see what gears it has. It also came out of the LSC with the disc brakes.
Anything to be gained by changing the ECM? I see people looking for the ones with the "A" code?
What kinda of gain to be expected by changing to the 1.7 rockers? That seems like any easy to do change if the perfromance is worth the price. Whats an average price for a set of rockers?
Thanks again
Changing the computer won't get you any real improvments in performance at your current HP level.
On a budget? do the junkyard upgrade...
Check the size ofthe MAF in your car. Stock was 55 MM for most early Mass Air engines.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
*1.) A metal flange adapter is available from: http://www.kustomz.com/cat3.html . Buy the TR70 for $44.95.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
The A2A, AA, AB, etc, on the end of the part number are minor changes that do not affect the calibration.
The rearend most likely has 3.27's. the top row of the tag should say 88327. the 88 means it's a 8.8"ring gear. the last 3 is your gear ratio. What's the car weigh? Best bang for the buck may be 3.73 gears and a transgo shift kit.
I will check the gears and see what they are, probably 3.27's.
Is there any benefit to changing the MAF up to the 65 or 70mm without doing any other mods? I was thinking of looking around for a gt-40 / explorer intake but need to figure something out first. Due to the tight space of the 36 front end, I had to flip the upper intake around and use a spacer to clear the brake booster. On the older style intake thats not a problem because you can mount it either way and it will still bolt on, I am not sure about the gt-40 though.
So is that true for the explorer intake as well? That setup has a ton of clearance on the drivers side. Even better than the older style. Is the trans and throttle cables easy to change over?
On a different note, I was going over things and checking the previous owners work when I discovered that he has the original MAP sensor plugged into the connector for the MAP sensor but with no vacumn line attached. I have read that they are similiar in function but calibrated differently. Should I replace it? It has a "Painless" wiring harness and the connector is labeled BPS (barometric pressure switch?).
