singleT 89GT
haha sounds about right... when its 105 out and inside the car feels like an oven then you put a fire suit on helmet hans device and shut the door... im glad im working on it and not in the driver seat...
i would like to drive it once though... on motor....
so lemme get this straight. u call me out to race...then tell me how i have to come on race day????
actually i called out mike joking...
my post to use was it looks like a blow through set up on alky.
now if you wanted to line up with the racecar... you dont wanna do that... im sure its been faster shutting it down coasting then you have ;)
Reactions: 88LX5.Oh
Again,....another assumption on your part. This car had a ladder bar crossover installed as well as the LB rear end brackets welded on the housing for people just like you.
So this car had both sets of mounting options.
Actually built so I could run it in either class,...or if I needed the extra stability/traction when going to a track where nobody cared how the rear end was suspended.
so u have a back halved turbo car with whee
thats cool man.. wheelie bars on anything less then a 10.5 out law car. is just
Uhh no.
Rules would not permit being back halfed and still run in a stock susp class. This car had the torque boxes where they were in their factory locations w/ tunnels cut in the rear floor to accommodate the ladder bars if I wanted to switch.
This car ran low 5 teens in the 1/8th when it wasn't killing itself trying to get an OH out of it. I built it myself in my garage in the winter of '07. While not an outlaw car by any scope, it was still stupid enough to get on a progressive wheelstand that started 60' out,...so......I chose the wheelie bars over the wall.
But I'm gay that way.
i sit with stock suspension.. you say someone has to match your tire? what susension dosen't matter? but tire size does? lmao!!!. i never herd of someone swapping from stock suspension to aftermarket suspension for ''stability reasons'' sounds like to me that statement is a front. no matter how much u play it off. you been stayed using LB's and WB's no reason to front its ok i aint mad at'cha.
but dont come on here talkin like u the man with ur back halved car to a Stock Suspension car..lol cause u come with that same car u just posted pictures of. and you come stock suspension no bars.. we can get a DP up asap.
:bang:
This car was built in 07 (seems I said that) back then, there were two classes, two set of rules, one provided for stock susp (EZ STREET) and one allowing a back half (LIMITED STREET). This car had both a stock floor, and a ladder bar crossmember w/ tunnels cut through for the bars to stick through the floor so that I could go either way.
Now,...( Read this part sloowly if it helps ) If you think a well set up LB car, isn't more stable than a stock susp car capable of a much more controllable pass under power, than I suggest you look up the word.
It's all irrelevant regardless. You post a picture of what looks like a drag car w/ a hole hacked through the bumper cover and nothing else w/ a tag that says I can't show you anything else because it's a grudge car???
I think Yeah,.....and?
Pictures are just that,....you want to impress most of the people on this forum by posting pictures of a drag car, a drag car that nobody can see anymore of than what could actually amount to a 11 sec bracket car ( I assume that's why you posted the pics,....to "share") Show me what you got racer boy.
never said they werent more stable.. i said i never heard of any one chaning suspension from stock to LBs depending on what class they are runing lol i said ur using the more stable statment as a front.
Why do you consider it a front? Sounds to me like he is a pretty good craftsman that opted to make his car more versatile simply because he had the talent to do it. Not a front, skill. At least that's how I see it. I don't think you get in trouble for people starting with you. Most of these guys come here to have fun, chat with like minded people about Mustangs and their hobby. Most are good at considering other peoples point of view and respecting other peoples likes or dislikes. I think it's your approach. NOBODY wants a confrontation. NOBODY wants mine is faster, mine is shinier, mine is the best and you suck. Try a respectful approach or they will ban you from the forums.
Reactions: S&B and 88LX5.Oh
