skippin problems
ThaBigE
i developed a skip not so long ago, ive ran out of ideas here... its an 89 fox, new ignition box, coil, control module, distributor, plug wires, new plugs and all, ive tested some pieces and replaced, motor was put together about 2 months ago and ran perfect until this problem came around. all parts are either stock replacement or msd upgraded, i just put the new plug wires on today and the minor skip turned into a pop...if anyone can help me out it would be much appreciated
timing
its set right at 16 degree, should be well within the limits with that cam and everything else done, ive tried backing it down just to satisfy my curiosity...it didnt help, so i put it back where i origionally had it set
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
the CEL isnt on, thats another nice thing to know lol
Codes may be present even if the CEL isn't on. Dumping the codes is easy and cheap: all it takes is a paper clip. If you can't afford a paper clip, you can't afford gas...
...its an 89 fox, new ignition box, coil, control module, distributor, plug wires, new plugs...
Stock 89 Mustangs did not have an ignition box. They had a distributor, TFI and coil. Some of your description does not match the OEM setup, so a better description may help.
