slipping clutch
  • Thread starter Thread starter 873Stang
  • Start date Start date Nov 12, 2007
873Stang
221
riverside
Nov 12, 2007
  • Nov 12, 2007
ok so driving say if im in first and pop the clutch to burn out it will just scream untill 4k then it thirps, or on the freeway in all gears if i step on it it revs high the goes to low rpms im 99% sure its my clutch but i only had it for about 6 months its a king cobra clutch
SuperStang83
1,693
Boyertown, Pa
Nov 12, 2007
  • Nov 12, 2007
At like 30-35 miles per hour put your car in 5th gear and push the gas all the way down. If the RPMs go up, but the car barely accelerates it is a bad clutch.
Redeemedsoul
70
  • Nov 12, 2007
This is true, but sometimes its more prevelant in some gears then others.. so basically I would say try it in 2-3-4-5 .. assuming you can... if it slips(rpm climbs and car stays at same speed) its 120% most likely your clutch..
-rS
Nibbie
127
  • Nov 12, 2007
you you can try a clutch test, if the clutch is bad start your car, put the e-brake on, press the clutch in and put the car in 4th or 5th gear. when its in gear let the clutch pedal up. Usualy your car will stall and die. if the clutch is slipping badly then it will stay on for a few seconds instead of turning off right away. This test usualy works most of the time. *dont face your car infront of any objects*
D
dec322
401
Bham AL
Nov 12, 2007
  • Nov 12, 2007
-rS
Agreed. The first trick wouldn't do it for me but I could be cruising in 3rd, press the pedal down to pass someone and the RPMs would just climb with no action at the wheels.
Also, my experience with a bad clutch made it impossible to do a burnout. The clutch wouldn't grab hard enough to turn the driveshaft/wheels. It would lead to alot of effort and a burning clutch smell.
baldy1
124
Portsmouth Va
Nov 12, 2007
  • Nov 12, 2007
If you do the e brake test put the trans in 3rd gear.
873Stang
221
riverside
Nov 12, 2007
  • Nov 12, 2007
yes indeed its the clutch so can bad adjustment cause this would i be able to adjust it to get more life out of it ive only had the clutch for 6 months im surprise it went out so fast, and also is ram clutches a good brand?
ninety15.0
1,336
  • Nov 13, 2007
When did you start driving a stick car? Are you good at it....be honest?!
873Stang
221
riverside
Nov 13, 2007
  • Nov 13, 2007
sence 16 im 20 now, i think it wore out so fast from burn outs and it was adj wrong which would be my fault
BYRDPE
1,556
Memphis,Tn.
Nov 13, 2007
#10
  • Nov 13, 2007
  • #10
Doing these incorrectly will make short work of any clutch.
I suggest you learn to do them correctly or stock up on clutches.
873Stang
221
riverside
Nov 13, 2007
#11
  • Nov 13, 2007
  • #11
lol well tell me how its done? i rev it then pop the clutch and hold the brake, is that the wrong way?
873Stang
221
riverside
Nov 13, 2007
#12
  • Nov 13, 2007
  • #12
whats the diff on clutch types as far as dual friction and 4 puck and 5 puck clutches
squeak93
2,352
418
164
Joplin, Missouri
Nov 13, 2007
#13
  • Nov 13, 2007
  • #13
Spec stage 2 is all you need to know. Had a few myself and spec is the best for the abuse u speak of. Too many burn outs though and u will get damn quick at clutch changes. You may want to invest in a second flywheel to already have turned to make the job quicker.
squeak93
2,352
418
164
Joplin, Missouri
Nov 13, 2007
#14
  • Nov 13, 2007
  • #14
Heel toe it. If you dont know how, learn. If you want to learn, it will most likely cost u some clutches.
Hold clutch with left (obviously) hold break with right heel, gas with right toe. Let up on clutch as u press gas slowly on each as to not shock the drivetrain and get tires going uncontrollably (like revving and dumping) You may need to adjust the amount of pressure on the break pedal depending on what the car is doing (if its moving press harder with the heal, if the car is dogging out let up a litte) Takes some practice but the best way I know of to do a burn out other than having a line lock or unhooking the rear brakes.
Have a real nice video somwhere of me doing this in my old 04 gt with a stock clutch and 4.30 gears. Lots of smoke and the only way to finish off old tires. I used to love doing burn outs and found myself replacing clutches. Now I realize I should just leave it to the track days to burn tires and clutches.
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
