slooooowwww wipers, help
  • Thread starter Thread starter phil5.0lx
  • Start date Start date May 24, 2011
P
phil5.0lx
26
  • May 24, 2011
i have a 1990 coupe and when i turn the multifunction switch from low to high for the wipers, the wipers do not increase speed, everything else on the multifunction works fine, brights, flash to pass, interval wipers, turn signals.. everything... but i have no high speed on my wipers....
anyway to check the multifunction switch? ohm it out? if so does anybody know what pins should read what when the switch is in different positions?... or is it possible my wiper motor is dead on the high speeds?
i would rather diagnose before throwing money at it. so thank you for the help
HISSIN50
34
129
May 25, 2011
  • May 25, 2011
An old post from Jrichker:
http://www.stangnet.com/mustang-forums/8010373-post2.html
Note the years listed - your '90 might be (likely is) different. I figured posting something was better than nothing in case it helps a little.
BlackGT89
774
Huntsville, AL
May 25, 2011
  • May 25, 2011
So on low you have no wipers, and in high they are slow ? If they are getting slower by the minute chances are your wiper motor is about to poop out on you.
P
phil5.0lx
26
  • May 25, 2011
no. i have wipers on low and high, they just do not speed up on the high setting
J
junkyardwarrior
Well-Known Member
Jan 10, 2011
400
113
63
May 27, 2011
  • May 27, 2011
Mine were doing that for a while too ('93 LX). Finally one night about 100 miles from home they QUIT working altogether. Before I replaced the wiper motor, I pulled the plastic cover and cleaned all the contacts. Still working to this day so it might be worth looking into.
Electrical 1986 Mustang GT Multifunction Switch Question
  • Willybill32
  • Oct 26, 2025
Fox 5.0 Mustang Tech Nov 22, 2025
Willybill32
A
Resolved Windshield wiper troubleshooting - Wiper turns OFF when Headlights turned ON
  • afjLX
  • Feb 9, 2025
Fox 5.0 Mustang Tech Mar 30, 2025
General karthief
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
F
Wiper motor relay? Motor? Multifunction switch?
  • Flinchum87
  • Jul 15, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 15, 2024
Flinchum87
F
