Sloppy steering but not the typical problem
Might not be tight enough. There's also another bolt holding that u-joint to the steering column in the dash - it might be loose. Best bet is to stick yuor head under there and move the steering wheel. If the wheel moves and the steering shaft does not, something has more play than it should.
maybe thats what it is because it has something to do with it above where the lower shaft connects.
