slow rpm drop, is it normal?
D347643
Banned
Jan 28, 2003
1,095
portland, OR
i had a quick question,.... when i rev up my car the rpms come down slower than id like. now my friend has a carbed 350 and the rpms drop with a snap. i know carbed cars are dif than fuelies and my iac is practically brand new so i know its not getting caught up or anything. anybody have any ideas or is that normal... almost makes me want to buy a lightened flywheel
thanks,
Drew
Are you rolling or standing still?
EDIT: When you are slowing down for a stop, the VSS sensor located on the speedo cable adapter on the trans tells the computer to slowly decrease the engine speed to keep the engine from stalling.
Standing still - WD40 all the throttle linkage real good.
I dont know if its the same thing you're talking about, but when I shift, the RPMs dont drop right away. Say I shift at 3k rpm at a moderate speed, by the time its in gear and i let off the clutch, the rpm has JUST started to drop. Theres a delay... is that normal, or a tune issue?
Could there be a diff betweent he aod and t5 ecu? My converted t5 car running the stock aod computer drops fast between shifts, if i shift too slowly the rpms drop too much. On the other hand, when i rev the engine, it drops to 1000, pauses, and then drops to idle. I'm thinking its a vac leak or sumthing, but a the same time, I also wonder if its a function of the aod puter?
Mine does the same thing. RPMs drop real slow whether I'm revving the engine or I've pushed in the clutch and am coasting to a stop. It also "hangs" at 1000 for about a half second or so then idles down to about 650. This seems normal on all the Mustangs I've driven. I've put it on a computer at Ford when my MAF was out, and it didn't pull any other error codes. I'm not worried about it. My car runs like a bat out of hell considering I haven't done a lot to it.
