Slow...WTF why
Nitrous is now hooked up! But...Damn rain spoiled the fun at the track tonight... Definately much faster and thats only with a 100 shot, Gotta tune it and figure out where the sweet spot is for fuel with the wideband and then start all over again with a 150 and then the 200 shot.
Total timing is at 34 or 35 degrees total (approx 30 total with the retard) right now. (Two heavy silver springs and the Blue advance stop bushing in the MSD dizzy and 14 degrees inital timing.) I also have an MSD 8680 adjustable timing control and its retarded 4 degrees right now. Spark plugs are Autolite 23's so two heat ranges cooler, Only going to be running 94 octane. Im going to keep playing with it until im happy/run out of all three bottles of nitrous/run out of tires/Get a ticket...etc etc, You choose! Any way you look at it im going to have fun for a while!!!
Well I ran it with the nitrous...(100shot) Definatly need to mount and run the slicks got a very traction limited 13.095 @ 102.30mph
Still doesnt feel like its pulling hard enough at the top end but I will figure it all out!
Tc 19c
SP 895 hPa
RH 31%
VP 6.813 hPa
DA 4747 ft
Dont have a clue what it would be time wize calculated for sea level but hey... Im not at sea level!
I don't see suspension on your nut and bolt list? If you want down the track fast you haft to hook. You are leaving 4 tenths on the table in the first 60ft. That is 8 tenths at the big end!
its already been said but heads alone will make it feel like a different car. I have experience with this. I had basically the same combo as you: Fcam, stock heads, exhaust, intake, gears, stall and was running consistant 14.6's. Switched to AFR heads and 24# injectors and it now runs 13.3's all day. So i picked up close to a second and a half with just heads!
Well I'm into the 12's :D [email protected] still on the 100 shot heres the rundown...
60' 1.878
330' 5.290
1/8 8.201 @ 84.19mph
1000' 10.743
1/4 12.909 @ 104.35
run was at 9:04 pm
6pm
Tc 15c
SP 886 hPa
RH 40%
VP 6.822
DA 4626
7pm
Tc 14
SP 886
RH 42
VP 6.715
DA 4510
8pm
Tc 12
SP 886
RH 50
VP 7.013
DA 4282
9pm
Tc 13
SP 886
RH 46
VP 6.890
DA 4397
10pm
Tc 12
SP 885
RH 48
VP 6.733
DA 4316
I am extremely happy with this as I still plan on running a 200 shot and this winter may be turboing the car with a 351 and megasquirt for tuning. We will see how plans unfurl!
