Slower Than Stock?
smokiez
22
norman, ok
Im new to forum but wondering if anyone could help. I have an 01 gt with the normal bolt ons, but everywhere I see ppl running low 14s completely stock. Out it out to the track and it and the best I could pull was 15.4 at 92.8 mph. It pulls decent just not the times I think it should be. Previous owner says they put stage 2 comp cams in it but not sure. 4.10 gears coming soon. Any ideas would appreciated.
bhuff30
6,037
35
129
Olathe KS
That certainly sounds off the mark, but keep in mind there are a lot of factors here. First of all, cars never run as quick as you think they *should* at the track, especially your first few trips out. Sometimes, it is weather, or maybe just driver technique. I know here, the weather wrecks havoc on times... we are at 1,000ft (more effect than you would think), and it is often hot and humid.
If you were driving the car well, it should go quicker than that though.
If there were any mechanical issue with the car, I would take a guess that the cam timing is off.
smokiez
22
norman, ok
Sorry for the late reply. Its a 5 speed coupe. The first couple run of the night I didnt get traction. I launched around 3100 or so rpm and no spin at all on later run with a .357 r/t but 2.36 at the 60'
smokiez
22
norman, ok
Its had a full tune up now and discovered something that im extremely unhappy about. Changing plugs I came o the rear cylinders and one side it had one of the plug kits in it and the other side is held in by jb weld. Guess next time I buy a car im gonna look at tbe plugs.
03_TrueBlue_GT
810
41
29
Houston, Tx
You mean the coil was not bolted into the manifold and they used jb weld to hold it in? When changing the plugs on these cars you can break the brass fitting that the screws fit into for the coils. This happened to me and I had to remove the old brass fitting and insert a new thread for the bolt to screw into. So yeah that probably happened to the previous owner. I dont see it affecting performance as long as its not too loose and doesn't loose its connection to the spark plug.
1987stangman
684
23
That's what made me nervous about buying a Mustang with a Windsor motor. Even though mine was bone stock I pulled the cops and plugs to make sure. The old lady I bought it from thought I was nuts. Yours is an 01 though it should have a Romeo unless it was an early model.
