  • 1994 - 1995 Specific Tech
smog ac help please
  • Thread starter Thread starter donnie84
  • Start date Start date Apr 8, 2005
D
donnie84
52
  • Apr 8, 2005
i wanted to use the asp smog pump delete, what can i use for the ac? asp? or FRPP
SmokinGT50
733
Atlanta, GA
Apr 8, 2005
  • Apr 8, 2005
you don't need an A/C delete on these cars
JJ95GTID
1,141
Phoenix, AZ
Apr 8, 2005
  • Apr 8, 2005
I'm pretty sure you don't need any delete pulleys. Just run a shorter belt and bypass the pulleys for the AC and smog pump.
cavscout371
277
  • Apr 8, 2005
yup here yah go can't remember who I got this off of
JJ95GTID
1,141
Phoenix, AZ
Apr 8, 2005
  • Apr 8, 2005
The red dashed line is wrong in this pic. Should go from the smog pulley to the bottom of the crank pulley. Up and around the water pump pulley down to the A/C pulley. But, you can see that before you pull off your stock belt.
cavscout371
277
  • Apr 8, 2005
who really cares what the red one is but thanks for pointing that out
JJ95GTID
1,141
Phoenix, AZ
Apr 9, 2005
  • Apr 9, 2005
Well, if someone actually followed that diagram and installed it that way the water pump would spin in the opposite direction than it is supposed to. Just trying to be proactive and prevent a problem.
D
donnie84
52
  • Apr 9, 2005
what do u mean these cars dont need ac delete? i wanted to get rid of the ac and smog to save like 40 or so lbs off the front end and make the engine bay a lot cleaner. you guys are saying i dont need to buy any pullies just run a shorter belt? what about when i wanna do a s/c?
canadian94gt
139
Debert, Nova Scotia,Canada
Apr 10, 2005
  • Apr 10, 2005
Either way the pully's would still turn the same way
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
M
Idel control valve
  • miser143
  • Oct 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
General karthief
