Smog pump delete question
  • Thread starter Thread starter sweet93hatch
  • Start date Start date May 9, 2004
sweet93hatch
57
  • May 9, 2004
First of all, where is this thing and secondly what is the advantage to deleting it from you ride? Thanks to all.
D
Dave14
193
Calgary, Canada
May 9, 2004
  • May 9, 2004
It is located at the bottom left of your engine on your accessory belt(looking from the front). The main reason to remove is just to clean up your engine bay. It also reduces about 20lbs. I think i got a little better gas milage after i removed mine too. Hope this helps....
Dave
sweet93hatch
57
  • May 9, 2004
Thanks Dave. Thats what I was looking for.
shorty1993
212
Gadsden, AL
May 9, 2004
  • May 9, 2004
make sure that you plug all of your lines correctly. you should have no problems finding the info in search, i did. very good details.
T
TheUser
1,859
Springfield, MO
May 10, 2004
  • May 10, 2004
you might try researching it a bit more before you go pulling it. The smog pump puts air in the cats to help mix w/ the exhaust to make it easier on the cats (basically). If you have cats and you delete the smog (air) pump, you're gonna screw your cats up...eventually. That's the general idea anyway. I'm almost positive Michael Yount had a very good and detailed post on this, so maybe try running a search for smog w/ Michael Yount as the poster.
shorty1993
212
Gadsden, AL
May 10, 2004
  • May 10, 2004
i thought the pupose was to pull the exhaust gas up through the engine. this would also involve the egr...or so it was explained to me. also if that were the facts, what about the front two cats, mine had four as i think his would to. however i have been wrong before. are you in a smog controlled area, if not ditch the cats and it wont matter.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
