smog pump delete
  • Thread starter Thread starter txgunrunner
  • Start date Start date Aug 3, 2005
txgunrunner
68
houston, tx
Aug 3, 2005
  • Aug 3, 2005
do you guys use the smog pump delete pulley or run a shorter belt and route it w/out the smog pump. thanks
Xterminator03
157
NEW YORK
Aug 3, 2005
  • Aug 3, 2005
use a shorter belt
stang22
1,318
Washington, D.C.
Aug 3, 2005
  • Aug 3, 2005
Think a shorter belt is around $30.00 and the pulley is around $50.00. I just ran a shorter belt.
Tim
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Aug 3, 2005
  • Aug 3, 2005
Just run the shorter belt and keep the pump handy, you never know when you will need to pass emissions!...Or just sell it on ebay!
The Shape
2,224
East ARKANSAS Delta
Aug 3, 2005
  • Aug 3, 2005
I use the short bus. Err short belt yep thats it.
Curse
791
El Paso, TX
Aug 3, 2005
  • Aug 3, 2005
Another vote for shorter belt.
Saleen8786
209
Marlton, NJ
Aug 3, 2005
  • Aug 3, 2005
i just used a short belt and let the smog pump sit on the motor for about 2 weeks, then i got around to taking it off(looks alot cleaner with it off
Scorcher2005
883
South Carolina
Aug 3, 2005
  • Aug 3, 2005
why would you want to take off the smog pump? It helps w/ emmissions, improves mileage, and de-activates at WOT. The only con is the space and weight it takes up.
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Aug 3, 2005
  • Aug 3, 2005
people "think" that the smog pump eats up 15hp from the engine for some reason? Me, I removed it for weight and I don't have cats and don't need to pass emissions.
Reactions: Nikia
A
ac09lude
14
Long Island, N.Y.
Aug 3, 2005
#10
  • Aug 3, 2005
  • #10
what do you have to do to remove it?
mustangjoe87
364
Harrison Twp., Michigan
Aug 3, 2005
#11
  • Aug 3, 2005
  • #11
mine locked up so i tossed it and got a UPR eliminator pully. i dont know why i guess i just wanted it in case i had to throw another pump back in. plus it matches my alum. U/D pullys.
Daniel50
716
Discovery Bay, CA
Aug 3, 2005
#12
  • Aug 3, 2005
  • #12
unbolt it. three bolts hold it in. then take out the two lines that run above the passenger side header. disconnevt them from the back of the heads. plug the heads. and call it a day
Saleen8786
209
Marlton, NJ
Aug 3, 2005
#13
  • Aug 3, 2005
  • #13
it's easy but kinda frustrating on mine the bolts were super tight and once their all off. You have to just grab twist a little and finese it out, thats the only pain in the ass is taking it off you slowly just have to work it back and fourth..goodluck
legalize420
1,541
South Florida
Aug 3, 2005
#14
  • Aug 3, 2005
  • #14
fwiw, im not sure if it is different on a fox but i had to take off six bolts. i had to take the pulley off the pump before i could slide the top bolt out. are the accesories on the fox motor in the exact place as the sn95. im pretty sure they are different but i could be wrong and just wanted to be sure.
89stangalang
58
#15
  • Aug 3, 2005
  • #15
I got the smog pump delete instead of the shorter belt because I need it there for the vortech Bracketry and I have no cats anyways with the offroad x-pipe.
maverick0716
3,924
Chilliwack, BC, Canada
Aug 3, 2005
#16
  • Aug 3, 2005
  • #16
How do you run a shorter belt? The belt would hit the tensioner
Scorcher2005
883
South Carolina
Aug 4, 2005
#17
  • Aug 4, 2005
  • #17
http://fordmuscle.com/archives/2000/02/shortbelt/index.shtml
spyder982
tx
Aug 4, 2005
#18
  • Aug 4, 2005
  • #18
smog pump delete pulley. looked good.I deleted mine because mine's pumps or bearings made a really loud whining noise. also worked good with the under drive pulleys!
QDRHRSE
1,590
Palmdale, CA
Aug 4, 2005
#19
  • Aug 4, 2005
  • #19
Pulley.....I have to have it for my blower. I would use the pulley anyway. Makes getting a belt a lot easier.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
