You can simply remove the smog pump and then get a shorter belt. Make sure you route the belt correctly so the water pump is spinning the correct way. The smog pump eliminators are generally for supercharged applications, where you need an extra pulley there to route the belt for the SC, such as Paxton and Vortech. No part # on the belt, sorry.
