SMOG STUFF ON BACK OF THE HEAD?
The two things that go into the back of the head can be flipped around and bolted in backwards, so that they cover up the hole in the head.
Or you can pick up the Trick Flow pieces that screw into the head blocking that passage.
zenboy99 said:
I agree, thats a better idea than giving Trick Flow your money. Many of us have given them enough money already.
The only issue is cleaning the carbon out of those holes.
it took me forever to get the bolts in. i threaded them a bit then took them out and cleaned the bolts, then threaded them a bit more and cleaned the bolts again. it took me about an hour to get both bolts in flush.
