smoke then dead...
  • Thread starter Thread starter alludethis
  • Start date Start date Sep 6, 2006
A
alludethis
58
  • Sep 6, 2006
I posted last night that my 5.0 was smoking like crazy thick white smoke. Found that antifreeze was indeed leaking into the intake, so I fixed that. I was trying to get the timing squared away, adjusting it then going out and testing it. Went to turn around and it died. Tried to start, my distributor just grinds as it tries to start up. So now I'm screwed with that, and have to replace that. My other question is how much is this car suppose to smoke?? It has headers with basically straight pipes, no cats no mufflers just 2 resonators, 1 on each pipe. I have a trail of smoke that follows me down the road. It's fuel I know that for sure, but why is there so much? Is it supposed to do that? What I'm thinking is that since the distributor just died, perhaps the spark wasnt hot enough to ignite all the fuel so it's dumping out the exhaust. It makes sense to me but I don't know for sure. The car has 170,000 miles on it, I don't know if that makes a difference to any of you.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Sep 6, 2006
  • Sep 6, 2006
Well do a comp check, and go from there, and put a new gear on the dist, or just get a new one, all that wear and tear on the dist, it will affect things, but not make it smoke, If its smoke, what color is it, white? Let it idle, rev it hard a couple of times and then open the oil cap, if white smoke is coming out it is more than likely the valve guides or the stem seals. The fuel issue isnt the prob here, you cant run enough gas through one of these things and make it smoke like this, I know cuz im going through the same crap as well, mine is the valve seals. Check your fuel press, on the shrader valve, just put a air gauge on there and see what it reads. Should be at 32-32 when it primes, and then when you start it it shold be the same, pull the vac line and it should go to about 40-41. Another thing to check would be the air temp sensor and, the pcv valve. And welcome to stangnet!!
Josh
A
alludethis
58
  • Sep 6, 2006
Hey thanks man. I tried to do a compression test and either I'm an idiot or the ignition is set up wrong. I pulled the wire off of the ignition box itself and tried to turn the car over and got nothing. I had a 5.0 before and all I remember doing is hooking the tester up, taking the wire off of the cap and cranking the engine to get the reading. Also there is a sometimes loud knocking sound, sounds like its coming from underneath the valve cover, I'm thinking about just tearing it down and doing a rebuild. I think I would have less to worry about. Does anyone know where to get a good engine rebuild kit for not to much money??
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 6, 2006
  • Sep 6, 2006
If the engine was getting coolant induced into it and the oil was not changed after the repair was done to stop the antifreeze getting in, I'm fairly certain the bearings are going to be pissed quite quickly...change the oil ASAP.
A
alludethis
58
  • Sep 6, 2006
already ahead of you. I changed the oil already.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 7, 2006
  • Sep 7, 2006
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading.Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
eagleautosports
139
Mebane NC
Sep 7, 2006
  • Sep 7, 2006
I have a DSS 306 crank kit for sale in the classifieds (don't bust me Tim, please). Where are you at? If you're interested, hit me back with your zip code and I can find out about shipping. If it's eaten up the bearings, you'll need a full rebuild, no matter where you get the parts from.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
H
New Built 91 Foxbody electrical failure. Need help
  • hassler
  • Aug 18, 2025
Fox 5.0 Mustang Tech Aug 21, 2025
limp
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
