Smoke?
  • Thread starter Thread starter ddt4436
  • Start date Start date May 4, 2009
D
ddt4436
70
  • May 4, 2009
I just changed the headgaskets on my 91 gt and changed the intake gaskets while installing a 1996 explorer intake. I didnt drill for the ACT sensor and I can't locate the other EGR water inlet on the back lower intake. Anyway my car smokes(white smoke) like hell especially when I press the gas and runs really crappy. There is some condensation along with a milky substance coming from where I put oil in the motor. I checked the oil stick and there is no oil mixing there. Could this be a intake leak? Help......
skunk21
1,203
Taxachusetts
May 4, 2009
  • May 4, 2009
you are drinking coolant. since you just did head & intake gaskets you need to recheck things. when you did the intake gasket did smear a light coat of rtv around the coolant ports on the heads? I would redo the intake gasket job 1st and make sure all the surfaces are clean, rtv around the coolant ports, follow the torque specs but go over them atleast 3 times until the wrench clicks at the right torque on the the bolts. Then let it set and try it, if that doesn't work you are going to have to tear it all down and check the head gasket, hopefully it's just the intake. Did you prep the head and use new bolts?
D
ddt4436
70
  • May 5, 2009
Thanks for the reply buddy. I used new bolts and the heads was prepped. I gonna take the intake back off and try again like you said.
L
Lawbreaker5.0
543
Texas
May 5, 2009
  • May 5, 2009
when i first did the my head gaskets i smoked for a good amount til it burned off the coolant and oil that i spilled on the headers. I would drive it a little longer before you go pulling it back off. is it coming out one exhaust or both?
D
ddt4436
70
  • May 5, 2009
It's coming from both pipes and really bad. When I take off the oil cap, steam is coming from it and there is that milky substance around the edges. There is no oil or water mixing at all when I check my oil stick though.
D
ddt4436
70
  • May 6, 2009
Anymore advice?
white 89 GT
281
Tacoma
May 6, 2009
  • May 6, 2009
Yeah take a comp. test, pull all the plugs have someone turn motor over and look for any fluids that may come out the plug holes, when you put the head gaskets on did you put the end marked front on the front ?
You most likely will not have what your saying with an intake gasket, both in oil and out exaust.
D
ddt4436
70
  • May 7, 2009
Ok thanks. I wonder why there is no water/oil mixter when I check my oil stick. The oil is perfectly ok. It's only steaming from the oil cap and running rough.
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
