Whenever the car is running everything is fine. However, when I turn it off, a minute or so later white smoke starts pouring out between my secondary cat and primary cat. I've cleaned them off with degreaser and acetone so its nothing on the surface that's burning. It's also only occuring on the passenger side. No smoke comes out of the tail pipes either. I've done a compression test, and the compression was the same across all cylinders.
The smoke smells pretty terrible. I can't really compare it to anything.
