sn-95 electric fan in a fox body
Blue89gt
404
Denver Colorado
I bough an electric fan for my fox today, and wanted to get an idea of how to wire it without a switch on the dash.
where can i get a thermostat for the fan how do i hook it up.
all the fan has on it are a pos. neg. and the center prong.
thanks in advance.
I have the sn95 elec fan it has 3 prongs LOW HIGH & Ground. if you look close at the plug area I think it has + + - on it. I ran a heavy gage wire to the 30 amp blower motor circuit and tapped into the fuse on the fuse box and it runs on high all the time. I gounded it near the fan to the body. Never gave me a problems.
If you want to run a temp switch than you would have to use relays. A friend tried to hook up a straight connection and burnt the temp switch. You can get them from summit. I have a diagram at home of how I got mines wired up. I'll try to post that later.
wow the dccontrol.com product is nice.. i didnt want to spend 80 bucks though. i am probably going to run the fan with a switch for now and get the controller when i am not broke...
what gauge wire should i run for the power circuit?,what size fuse, and i should be able to wire the fan to the battery (power, heavy gauge) and then post fan have the switch in the ground side of the circuit as to lower the amount of current going through it.(smaller gauge wire)
or do i need some form relay to reduce the current through the switch.
"do i need some form relay to reduce the current through the switch."
Yes - definitely a relay; you'll spend $$$ trying to find a switch that will stand up to the current. Same is true trying to find a single relay to stand up to the current. I found that over time using the proper quality temp. switches and relays, I spent just as much (more by the time I got through finding the right combination of switches and t'stats) on all the gear as I would've if I'd just bought the controller to start with.
Agreed.
If you actually purchase the proper gauge wire, fuses, switch(es), and relay(s), you will likely have spent close to what the www.dccontrol.com unit costs and still have an inferior fan controller.
I use a C-H-E-A-P Hayden controller that triggers a Bosch 75a relay. It works well, but the controller was $20, the relay was another $20, and the associated wiring, loom, fusible link, etc was probably another $15-$20.
Granted, when I put my setup together, the DCControl unit was not yet available. If I had to do it now, I'd definitely pony up the extra $20 or so and have a much more elegant (and functional) setup.
BTW, you will need the same gauge wire on the negative side as the positive side. Just as much current runs through there as through the positive.
I got a 30 amp relay today, and it seems to work so-far.... now here is another question... where do i put my coolant overflow bottle(coolant reservoir).. i do not have one.
the fan is toward the drivers side of the radiator (not centered) and thier os no place to really mount it... what are my options? and how did you do it....
thanks.
Well keeping the stock overflow looked a little tacky to me. I went out and got one from autozone.
Anyone use the DCControl unit on a Mark VIII fan? I was reading through the specs and it says that the continuous draw can be no more than 60amps. Doesnt the Mark VIII and the SN-95 fans draw close to 100amps at startup and more like 75 amps running?
Also the ones on the sight now are like 144.95 for the 60 (The one I think should be used). Isnt that a little steep for a controller?
Stang951 - surf around the Delta Control site some more; Brian has EXTENSIVE experience driving the MkVIII with his controller; in fact he sells the two as a package kit. It won't have any problems handling the fan. If you read up on it more, you'll see that the controller varies the current to control the fan --- no more start up spikes. It's one of the many benefits of the device - much easier on the alternator, fan motor and serpentine belt assembly. It 'ramps' up the current to start up the fan. The continuous draw from that fan even at full 'throttle' is less than 60A. But very few applications will ever see full draw - that's the beauty of the system. Instead of cycling it full on/full off, it controls the current/fan speed to move only enough air to cool the system. On most Stangs, with a MarkVIII fan, I doubt it would ever even come close to hitting full current.
I've got one of their 35A controllers working my dual 11" SPAL shrouded set up. They pulled 34A continuous with the old switch/relay control. It's a night and day difference with the DC unit - smoother, quieter, more consistent temps. In a word - ELEGANT. It rocks - nothing else even comes close.
If you want the controller by itself, it's $114.95 (by what I saw on the site); the $144.95 is for the install kit too. I bought the 35A kit for $109 -- WELL worth the money. You can not imagine how much more seamlessly this thing controls the fan. It's a night and day difference. Only you can determine what you're willing to pay for something; my only regret is that I didn't find this before I spent just as much on various switches, relays and wiring only to have a very inferior control system. By the way, most folks thought my dual temp switch, dual relay control set up was one of the best they'd seen. It was a neat system if I do say so myself - but it doesn't even come close to the dc unit when it comes to controlling engine temps with minimal parasitic losses, minimizing noise, and minimizing system wear and tear on the car/motor. Not that I'm a big fan (no pun) or anything....
well, i got the coolant reservoir the same as in the picture.... the big problem was getting it down there. i have the SC and the belt was a little close. the alternator was almost in the way. i had to put the res on the bottom, and then just put it up against the canister(its at an angle).
for now i bought this relay from checkers and it seems to work for now... but i'll probably go with the Dcontrol unit when i can get the dough.
i have to replace my alternator, it is still the origional (216k) and i think im going to go with the newer version. (130a.)
but other than that the car is good for now. :rlaugh:
You may find that the fan does your original/stock alternator in, and/or your battery if you're not lucky. If you have a voltage gauge keep an eye on it. It's usually marginal for the 65A alternator with an electric fan of any kind - especially if it's cycling on and off with a relay.
I just wanted to say thanks to Michael Yount for bringing to our attention the dc controler. It is an awesome product! :nice: I had my SN-95 fan hooked up to a dual relay setup. I modified a rear window defoger switch to turn it on or off. (I don't have rear defog on my car. Just got the switch from the junk yard.) It works well and the temp always runs cold exept for the spike in the charging system and constant high draw on the charging system. Also I don't like the idea of having to turn a switch on or off all of the time. :notnice:
Thanks again :D
Thanks again :D
Seems like a pita to remember to turn the switch on and off. That's why I have mine on a temp switch. But I do like the dc controller and I'll most likely get it when I get the extra cash.
