**SN95 Clutch Fork & Tranny, on Fox Question!!!**
FiveOhhStang
299
Sanger, Cali.
Im putting a 94 cobra tranny in, with the newer bellhousing too, and the problem is......
My newer clutch fork has a weight on it...it looks like it can be taken off, but im not too sure when the purpose of the weight is. Do I need this on there, or just take it off?
__________________
from what I understand, you're gonna want to use the stock 5.0 fox clutch fork with that, if you don't have one, diversified sells one with an oem cable for $40.
the 94 t5 also has a longer input shaft that you're gonna have to compensate for I "think" by swapping bells, you're gonna have to investigate that.
Im putting a 94 cobra tranny in, with the newer bellhousing too, and the problem is......My newer clutch fork has a weight on it
The weight can be removed. I took mine off a long time ago. Still haven't figured out what it's purpose was. I wouldn't mind having your stock Fox fork if you're interested in getting rid of it. Use them when putting Tremecs into SN95 cars.
