  • 1994 - 1995 Specific Tech
Snapped valve cover bolt!!!!
  • Thread starter Thread starter 95Cobra302
  • Start date Start date Oct 25, 2011
95Cobra302
394
Daytona Beach, FL
Oct 25, 2011
  • Oct 25, 2011
Was torquing my valve cover bolts at 10 ft lbs and one just snapped!!! It was the lower middle bolt on the driver side. You think it will still be ok and not leak??? Damn, I'm so pissed!!!!!!!!!
RIO5.0
6,892
N.H.
Oct 25, 2011
  • Oct 25, 2011
You might luck out with new gaskets??? Is it all below the surface or any sticking up??
95Cobra302
394
Daytona Beach, FL
Oct 25, 2011
  • Oct 25, 2011
Its below, if any was sticking up I would have used a vise grip and tried to unscrew it.
RIO5.0
6,892
N.H.
Oct 25, 2011
  • Oct 25, 2011
I was thinking cutting a slot in it.... sounds like you need to drill and use an easy out. ... should come out pretty easy at the amt you tq'd it.
SableSal
295
Fresno, Californ-I-A
Oct 25, 2011
  • Oct 25, 2011
Don't rig it. Remove the bolt. Drill and Easy-Out. Drill will probably do it. Honestly a pretty easy job. I've taken out worse.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 25, 2011
  • Oct 25, 2011
That's always a pain. I had two snap off in one of my old cars, and I managed to keep it from leaking. I actually drilled the bolt out, and snapped off the tap in there too. I ended up having a machinest break out the taps.
Kurt
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
