So frustrated!! Thoughts Please
  • Thread starter Thread starter JS94cobra
  • Start date Start date Mar 24, 2006
J
JS94cobra
Banned
Mar 8, 2006
58
NJ
Mar 24, 2006
  • Mar 24, 2006
Hey guys I've been having a bit of a problem with my cobra. I have this annoying noise occuring and it doesn't matter if the car is under load or in neutral. If I accelerate under load the noise is more noticable than if its in neutral but I can still hear it if I rev the engine quickly. I don't really know if i can describe the noise accurately but its sounds like a cross between an exhaust leak and pinging. When I first started to diagnose the problem i thought it was pinging. Checked my timing, put 93 oct. in, changed all spark plug and wires. After that changed header gaskets, tightened all exhaust connections. Put a clamp of the smog pump tube to bassani x-pipe. It sounds like its coming from underneath the car but now I am stuck. I don't know where to look next. can someone help me. Thanks
Paul Perreca
1,085
  • Mar 24, 2006
pull the valve covers n check the rocker arms... good luck man, i had this problem, but it was my timing
J
JS94cobra
Banned
Mar 8, 2006
58
NJ
Mar 24, 2006
  • Mar 24, 2006
Thanks I will see if I can get a day to do that. Maybe this weekend.
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Mar 24, 2006
  • Mar 24, 2006
I also have a tick in my engine...it really sounds like its either coming from the rotor in the distributer or someing in the distributer or it could be under my drivers side valve cover. Is this side able to be taken off easily?
J
JS94cobra
Banned
Mar 8, 2006
58
NJ
Mar 24, 2006
  • Mar 24, 2006
It would be 10x easier on either side if intake came off. to take off passenger valve cover the intake needs to come off and drivers valve cover is a bit easier to access but still I think the intake would need to come off
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Mar 24, 2006
  • Mar 24, 2006
You can take a broom stick or long metal pole and place throughout the engine to locate the noise.
Ticking - Exhaust leaks / Rocker ticks / Lifters / Something loose
Knocking - Not good!
Can you isolate what side of the motor?
J
JS94cobra
Banned
Mar 8, 2006
58
NJ
Mar 24, 2006
  • Mar 24, 2006
It sounds like its coming more from the drivers side. Its hard to determine where exactly its coming from because its more noticable under load. I can't sit on top of the motor and listen where its coming from while accelerating. I might take a look at the rocker arms tomorrow.
any other possibilities???
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Drivetrain Why does my AOD make a 'whirrring sound' when in gear?
  • evintho
  • Feb 7, 2025
Fox 5.0 Mustang Tech Feb 15, 2025
evintho
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
