So how do u guys think this combo will work.
  • Thread starter Thread starter 5.0LOfFun
  • Start date Start date Jun 15, 2004
5.0LOfFun
81
  • Jun 15, 2004
Hey guys i just picked up a mint 93 lx 5.0 and am lookin to mod. this is what i would like to do. Stock 302 shortblock, a nice set of afr 185 cc heads, Systemax upper and lower manifold, ford E-cam, 70mm tb, 75mm maf, 30lb injectors, 3.73's, full exhaust. what do you guys think of this set up, will it work nice?
thanks, Rich
shawnandlo
southern california
Jun 15, 2004
  • Jun 15, 2004
i'd pick something other than an alphabet cam probably a comp somewhere around high 270s to low 280s advertised
30# injectors will be to much i've run 427 inch windsors with 30#s with out a problem
5.0LOfFun
81
  • Jun 15, 2004
ok so how about the 24lb injectors, those will prb work fine right? anyone have any coments on the heads or manifold?
drgn5.0
603
  • Jun 15, 2004
24lbers will be fine. afr's are great heads to get and the systemax II intake is the proven best power making 5.0 intake. there is nothing wrong with the e cam but you can make more power with a better suited cam with the whole combo.
DirtyD916
804
Norcal 916
Jun 16, 2004
  • Jun 16, 2004
making it a bad cam for the application ^^ id go with some nice long tubes, bassani x pipe and catback. MAybe save up for a really bullet proof low compression short block with a nice t-trim topping it off.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jun 16, 2004
  • Jun 16, 2004
30's are EXACTLY what you want with that combo! I run 30's in my 302 set up. Theres better cams than the E303 for the record..
runningmole
1,127
San Diego, CA
Jun 16, 2004
  • Jun 16, 2004
If you're going to buy AFRs get a custom cam too www.flowtechinduction.com
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
