so which NSS do I NEED?!
  • Thread starter Thread starter Foxfan88
  • Start date Start date Dec 13, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Dec 13, 2005
  • Dec 13, 2005
i have to have the one on the t5 hooked up right? what wires under my car do i hook up to it??
will the car start with the pedal connector unplugged??
carbed87
215
  • Dec 13, 2005
bump-ety bump bump
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Dec 13, 2005
  • Dec 13, 2005
im not sure what plug exactly but i would figure.. its a open bridge between the plugs so that means it should be telling hte computer dont.. but then again it had to start unless its hooked to some other thing for the aod..
old_blue
1,783
282
124
Dec 14, 2005
  • Dec 14, 2005
did you do a t-5 swap? assuming so, then you can just leave the one on the pedal on there. It is just a loop to bypass the NSS. But just remember that the car will start without the pedal being in. If you want the NSS, then in the wiring loom under the dash there is an extra plug near the top of the pedals that will fit on there for that.
as for the tranny-
I didn't buy any extra wires or anything when I whole v-8 conversion for the tranny. I just hooked up what I could and let it be. I am not sure what all the terminals do on the tranny but the ones I hooked up worked for the reverse lights and I know I left something unplugged (because I didn't have anything for it.) Someone else on here can tell you what exactly everything is for.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
