soft brake pedal
  • Thread starter Thread starter NFGTragedy
  • Start date Start date Oct 23, 2006
N
NFGTragedy
155
Rochester, NY
Oct 23, 2006
  • Oct 23, 2006
I was just curious what you guys think... When my car is off the pedal is rock hard but when the car is running its very soft. It stops the car near 1 inch to 1/2 from the floor. I have the stock fox booster/MC but I have a 5 lug swap with the sn95 calipers. I have heard that the sn95 calipers are horrible at holding air so I'm hoping its that but I also caught word that it might be my MC. The car had the brake lines unhooked for the 5 lug swap and I replaced the soft lines with braided lines. Thats why I think its just air... but also my booster/MC came from a parts car I had that sat around for a little over a year before it went in my car. Could the MC have gone bad then?
Should I try a bleed first or does this sound like a MC from the start?
85ragtop
BTW, I like dudes.
475
123
NC
Oct 23, 2006
  • Oct 23, 2006
I would give bleeding a try. Sounds like air in the lines.
stangjunkie
381
  • Oct 23, 2006
+1 sounds alot like air in the lines... had this problem on my old mans kit car which was lincoln disk brakes up front and turbo coupe rears (obviously to make it 5lug and 4 wheel disk)
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Oct 23, 2006
  • Oct 23, 2006
If it gets hard as a rock with the engine off its not really air in the lines. If the pedal were still spongy then, then i would agree that it was air though.
However, if you arer running SN95 brakes with SN95 disks out back, then your problem is an incorrect MC. You really should be running a 4-wheel disk MC, like the '93 Cobra, or 94-95 GT/V6 or 94-95 Cobra...and Sn95/93 cobra booster. You should really have an adjustable prop valve at this point as well
If you have just the SN95 fronts and rear drums, then i would lean more to a booster/MC problem.
But easiest thing to do first is bleed and rebleed. Sn95 REAR calipers are the ones notorious for trapping air. The fronts usually bleed fine. For the rear you should remove the caliper, turn it with the bleeder up, put a block of wood in it and bleed like that.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 23, 2006
  • Oct 23, 2006
for the 5-10 minutes it takes 2 guys to bleed them do that to start. Remember to start at the wheel furthest from the MC
RR
LR
RF
LF
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 23, 2006
  • Oct 23, 2006
and as soon as you crack a bleeder screw or unhook a line you must bleed the brakes.....
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes ATS brembos and drums
  • 5ptslow
  • Nov 16, 2025
Fox 5.0 Mustang Tech Apr 4, 2026
AeroCoupe
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
