soldering wires
  • Thread starter Thread starter riceslayer302
  • Start date Start date May 26, 2008
riceslayer302
Banned
Oct 3, 2006
CT
May 26, 2008
  • May 26, 2008
ok, i need to solder wires for my MSD 6AL box, i just need to lengthen the wiring harness and i dont want to do it wrong, all my electrical knowledge tells me not to solder wires in a location that will be under alot of stress from vibration. So here is what i was thinking, and i would really like you guys to either back me up or turn me a different way. Should i solder the wires and then wrap them in rubber tape with electrical tape over that? or should i just use connectors and wrap them?
347HO
462
Seattle
May 26, 2008
  • May 26, 2008
Use environmental splices which come with their own heatshrinking sleeve.
It is a crimp style connector and is sufficient even in inclement weather.
I suggest you use the light blue for or pink for wire gages of 24 and 20 respectively.
If you can find a local electrician shop, they most likely would help you and possibly even let you use their tools at no charge. But you'd have to bring your junk to them of course...
It's never good to use "tape" on connections. It's ugly and only temporary.
HISSIN50
34
129
May 26, 2008
  • May 26, 2008
I'm more of a fan of soldering, though crimps or solder joints done incorrectly are both equally lame. I worry about crimp connectors and NVH/heat more than decent solder joints.
If you want to solder, here's a decent article.
Good luck.
4G-KDMP
935
CA
May 26, 2008
  • May 26, 2008
^^^I agree
here is a article that might be helpful also.
http://www.teamnovak.com/tech_info/how_to/solder/
riceslayer302
Banned
Oct 3, 2006
CT
May 26, 2008
  • May 26, 2008
ahhh, very nice guys thanks alot
9
9050lx
33
  • May 26, 2008
Solder the wires,seal them from the air so they wont corrode,use shrinkwrap.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
May 26, 2008
  • May 26, 2008
If you DONT solder...+1 for using connectors covered with heat shrink...IM getting ready to do this myself.
Thanks
RC
Saleen0679
876
24
49
Yakima, WA
May 27, 2008
  • May 27, 2008
Another option is to find the weather-proof butt splice connectors with the solder inside. After you perform the crimp you use the heat gun to melt the solder and shrink the insulation at the same time.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
