Solenoid wiring schematic
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
Ill try to keep this simple.
I converted from EFI to carb.
I bought an aftermarket coil, Dizzy and 6AL.
I want to retain my stock gauges, lighting etc.
I need to see if someone has a schematic for the wiring harnesses that are on the drivers side of the car.
I just need to know what the wires that attach to the solenoid are for (to see if i need to eliminate any of them) Or so i can extend and route them differently. I dont want anything on there i dont need anymore, thats why i need the schematic or the drivers side harnesses and the solenoid. I also need to know if i need to splice the rectangular connector that plugs into the factory coil into the MSD coil i got. (shown in the last picture)
Thanks in advance!
attachment.php
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
Send me your offsite email address and I will send you the complete wiring diagram set for an 89 Mustang. The diagram set is a PDF document and is too big to pass through Stangnet's email gateway.
Solenoid Circuit
am trying to construct a solenoid simulation circuit that can produce more than 50strokes per second, one stroke is about 10mm, can anyone help me out...so stuck in this thing for weeks..
Solenoid Circuit
The solenoid will not react that fast. The inertia of the iron core will not allow it to happen. What is it that you are trying to do?
